New Arduino stuff to build your MIDI application
Page 1 of 1 [6 Posts]
xarolium
PostPosted: Mon Dec 10, 2012 11:59 am    Post subject:  New Arduino stuff to build your MIDI application
Subject description: found new MIDI shiel with adds very easy to use
I found on the web this stuff
maybe it will interested somebody
www.e-licktronic.com
xarolium
PostPosted: Mon Dec 17, 2012 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
the guy make a demo
Audio files: 151
PostPosted: Wed Dec 19, 2012 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Am I missing something? I don't see any midi cables connected, or is he using midi via the Arduino's usb port. If so, it would be cool to tap directly into midi from the usb port.
xarolium
PostPosted: Wed Dec 19, 2012 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
No there is no midi cable.
But you can choose between midi via USB or MIDI via DIN cable
When you're using USB you need this Software http://projectgus.github.com/hairless-midiserial/ to convert the serial signal to MIDI.
There is a good tutorial here http://www.e-licktronic.com/en/content/16-tutorial-dilicktal-usb
Audio files: 151
PostPosted: Thu Dec 20, 2012 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the links; I will check them out. It would be great to have midi from the arduino be available to the computer with a virtual cable.
Steve
xarolium
PostPosted: Wed Jan 02, 2013 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
E-licktronic create a new library to communicate with Dilicktal Board
Very easy to use and faster than ShiftIn and ShiftOut Arduino's function
All details here http://www.e-licktronic.com/en/content/19-tutorial-library-srio
Niio2
