Audio files: 705
Posted: Sat Dec 08, 2012 8:51 am Post subject:
Enneatronic Spectralizer Subject description: 9 oscillator dronebox with hypnotic LED display |
RingMad wondered how I achieved the fading on the audio for the Enneatronic Spectralizer so here's
the schematic and some extra info for those interested.
THE ENNEATRONIC SPECTRALIZER
The Enneatronic Spectralizer is a drone box containing 9 tunable squarewave oscillators with a
simple, 1 transistor, VCA section to fade the sound of each oscillator in and out. The same oscillators that
control the VCA's also control 42(!) LED's, arranged in such a way that it creates a constantly changing
display of symmetrical patterns.
thanks for posting that pic richardc64
The oscillators are all made with a CD40106 (3 chips in total) combined with some resistors, capacitors and
transistors to create the fading effect for both sound and LED's. Values were selected by means of experimentation
to get the result I was happy with. So if you want to use the circuit with a different supply voltage you'll probably
have to change some values. The fading of the LED's also varies with the kind of LED's used, so this will need
some experimentation aswell.
Each group of 3 oscillators (build around a single CD40106) also has a switch to turn the sound off. This makes
tuning a bit easier but can also be used to switch between differently tuned drones. The tuning itself is done
with a 47K pot (fine) in series with a 250K trimpot for pretuning (coarse). Originally the circuit was made with
just the 250K trimpots, but it was difficult to tune them pecisely so I added the 47k pots in series and
pretuned them to a low, mid and high section.
The sounds of the oscillators are mixed together with an opamp and then send out to a jack, which is wired up
in such a way that it can also be used as an EFX Send/Return for the build in amplifier. The amplifier itself is a
very basic LM386 setup. The 65Ω speaker was just something I had laying around that was small enough, so it
doesn't have to be 65Ω.
some extra info on the display:
- directly in front of the LED's there's a layer of frosted plastic to diffuse the light a bit. (cut from a box that came with some VHS tapes).
- on top of this is a blue lighting filter to dim the lights. (42 bright green LED's produce a lot of light! )
- followed by a green lighting filter which together with the blue creates a very nice shade of green.
- this is covered with a piece of perspex to protect it which also functions as a mirror if you turn the LED's off (bonus effect).
because there is some space between the LED's and the plastic it creates a sort of 3D effect were the brighter LED's
seem closer then ones that are dimmed.
(I added a photo which shows this a bit)
You can find a audio recording of the Enneatronic Spectralizer here
or watch this video to see it in action:
edit: uploaded the video directly to the forum
Description: |
Filesize: |
67.99 KB |
Viewed: |
1796 Time(s) |
Description: |
Enneatronic Spectralizer 3D effect |
Filesize: |
27.89 KB |
Viewed: |
955 Time(s) |
Description: |
Enneatronic Spectralizer - perf pr0n |
Filesize: |
77.2 KB |
Viewed: |
865 Time(s) |
Description: |
Video of the Enneatronic Spectralizer in action |
Download |
Filename: |
Enneatronic Spectralizer.wmv |
Filesize: |
130.39 MB |
Downloaded: |
902 Time(s) |
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider Twitch YouTube Last edited by PHOBoS on Thu Jul 21, 2016 10:36 am; edited 2 times in total |
Joined: Jan 15, 2011 Posts: 427 Location: Montreal, Canada
Posted: Sat Dec 08, 2012 9:01 am Post subject:
Wow, PHOBoS, thanks for all that documentation! So very generous of your time.
And let me say, because I'm feeling it strongly right now, that I love these DIY forums here on e-m... so inspirational and educational and fun and it keeps one going knowing there are other people spending hours soldering up crazy projects that most people would not understand the point of.
James. |
JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
Posted: Sat Dec 08, 2012 9:25 am Post subject:
This thing is great ... I was just hypnotised by it for about 5 minutes. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
Audio files: 705
Posted: Sat Dec 08, 2012 1:57 pm Post subject:
RingMad wrote: | people spending hours soldering up crazy projects that most people would not understand the point of. |
I think that's a pretty accurate description of me and a lot of other folks here. (and yes, I agree)
JingleJoe wrote: | This thing is great ... I was just hypnotised by it for about 5 minutes. |
I forgot to mention, it's like IT's "deadlights", once you watch them it's hard to look away
(and it might drive you insane, but it's probably too late for that anyway) _________________ "My perf, it's full of holes!"
dirtyworm
Posted: Sat Dec 08, 2012 2:47 pm Post subject:
Thank you for sharing this. It is helpful as I have been working on a vca type of circuit for my Lunetta and this is proving to be helpful in getting points that I was struggling with working to my liking.
Very cool housing you have created on the last few projects, the LED display on this one makes it that much more interesting. |
Audio files: 705
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Posted: Mon Dec 10, 2012 7:46 am Post subject:
PHOBoS wrote: | I forgot to mention, it's like IT's "deadlights", once you watch them it's hard to look away
(and it might drive you insane, but it's probably too late for that anyway) |
It reminds me of the Neural Neutralizer in the Dagger of the Mind episode of Star Trek (how much of a nerd does that make me?). Hope that it doesn't have the same effect... I really like the sound and look of this. Another thing to add to my list of ideas to try - I don't know if I'll live long enough to get through that list.
dirtyworm wrote: | Thank you for sharing this. It is helpful as I have been working on a vca type of circuit... |
Ditto for me. Those single transistor VCAs seem well worth a look at.
Gary |
nathanxl
Posted: Mon Dec 10, 2012 8:06 am Post subject:
This is really great.
I am hypnotised by it.
Id love to know/see more on how you layed out and wired up the LEDS to the VCAs. It truly is a fantastic effect. The orientation and fade rate is just superb.
Impressive |
Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Mon Dec 10, 2012 12:03 pm Post subject:
Frickin' awesome _________________ Zontar Prevails! |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Wed Dec 12, 2012 9:35 am Post subject:
Finally found time to listen & watch, lovely box! _________________ Jan
Audio files: 705
Ganzha
Audio files: 27
Audio files: 705
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Audio files: 705
Posted: Sun Jun 01, 2014 11:48 am Post subject:
Muied Lumens wrote: | Playing on the radio now - what a gorgeous sound! |
Biyi showed interest in making a spectralizer and was asking for a layout and more info so I'll just post that here.
First thing is how the LED's are wired up.
I just soldered them on a piece of perfboard and then soldered wires to the legs to connect everything together.
Here's the layout and a coloured map to show which LED's are wired together and to what knob they are linked.
D1-D2-D3 in series, connected to OSC A1
D4-D5-D6 in series, connected to OSC A2
D7-D8-D9 in series, connected to OSC A3
D10-D11-D12 in series, connected to OSC B1
D13-D14-D15 in series, connected to OSC B2
D16-D17-D18 in series, connected to OSC B2
D19-D20-D21 in series, connected to OSC B3
D22-D23-D24 in series, connected to OSC B3
D25-D26-D27 in series, connected to OSC C1
D28-D29-D30 in series, connected to OSC C1
D31-D32-D33 in series, connected to OSC C2
D34-D35-D36 in series, connected to OSC C2
D37-D38-D39 in series, connected to OSC C3
D40-D41-D42 in series, connected to OSC C3
However I would like to encourage anyone to make a different custom layout, maybe using different colors or combinations,
more or less LED's, LED displays, whatever you can come up with..
Description: |
Spectralizer LED layout for perfboard |
Filesize: |
61.77 KB |
Viewed: |
546 Time(s) |
Description: |
Enneatronic Spectralizer LED map |
Filesize: |
196.35 KB |
Viewed: |
720 Time(s) |
Audio files: 705
Posted: Sun Jun 01, 2014 1:08 pm Post subject:
Enneatronic Spectralizer perfboard layout |
Here's the original perfboard layout for the modules
I made 3 of those and later added the 47K pots. I soldered those to the edge of the boards as can be seen on this photo:
(I had to cut a small part off to get them in the box)
The 47K pots are connected instead of the connections between the 250K trimpots and 10K resistors using some wires.
Description: |
Enneatronic Spectralizer module layout (full) |
Filesize: |
145.21 KB |
Viewed: |
569 Time(s) |
Description: |
Enneatronic Spectralizer module layout (top) |
Filesize: |
118.27 KB |
Viewed: |
654 Time(s) |
Description: |
Enneatronic Spectralizer module layout (traces) as seen from the top, so it's mirrored from the actual layout |
Filesize: |
95.9 KB |
Viewed: |
635 Time(s) |
Description: |
Enneatronic Spectralizer module layout (traces + grid) as seen from the top, so it's mirrored from the actual layout |
Filesize: |
91.99 KB |
Viewed: |
548 Time(s) |
Description: |
Enneatronic Spectralizer the green wires are the connections to the 47K pots. |
Filesize: |
116.74 KB |
Viewed: |
544 Time(s) |
Biyi
Audio files: 705
Posted: Mon Jun 02, 2014 10:34 am Post subject:
The cap is a decoupling cap (I usually don't label those, nor draw them in schematics ) so 100nF would be fine.
And the circle is indeed a (3mm) LED, which simple shows if the PCB is powered, so you can leave that and the 1K resistor off the board.
I think I also have a layout for the mixer and amplifier section so I'll probably post that later. _________________ "My perf, it's full of holes!"
Biyi
Posted: Mon Jun 02, 2014 10:45 am Post subject:
Enneatronic spectralizer Subject description: Enneatronic Spectralizer |
hey, phobos my suspicion was confirmed ... fantastic! good job! |
Biyi
Audio files: 705
Posted: Mon Jun 09, 2014 2:38 pm Post subject:
Biyi wrote: | Hello everyone , this is an approximation of the Phobos Eneatronic Spectralizer. PCBs in pdf, one is the actual view and another the pcb. |
looks good:)
one small error though, the voltage regulator needs to be a 7810 (instead of 7805)
here's the layout I used.
(I'm working on a blockdiagram which shows how I have things connected)
Description: |
Filesize: |
280.92 KB |
Viewed: |
550 Time(s) |
Description: |
Filesize: |
253.33 KB |
Viewed: |
570 Time(s) |
Description: |
Filesize: |
154.27 KB |
Viewed: |
591 Time(s) |
Description: |
Filesize: |
296.89 KB |
Viewed: |
626 Time(s) |
Audio files: 705
Biyi
Posted: Wed Jun 11, 2014 11:30 am Post subject:
Ok guys..pcb,real view and sik components ready to print..for enneatronic, power and amp..enjoy. only remain leds(the must complicate for me...)..surely on perfboard. thanks . Phobos.
Description: |
Download |
Filename: |
Pychomanteum components.pdf |
Filesize: |
177.09 KB |
Downloaded: |
737 Time(s) |
Description: |
Download |
Filename: |
Pychomanteum PCB.pdf |
Filesize: |
41.48 KB |
Downloaded: |
608 Time(s) |
Description: |
Download |
Filename: |
Pychomanteum silk.pdf |
Filesize: |
10.86 KB |
Downloaded: |
727 Time(s) |
Description: |
Download |
Filename: |
Pychomanteum power & amp ready components.pdf |
Filesize: |
80.66 KB |
Downloaded: |
590 Time(s) |
Description: |
Download |
Filename: |
Pychomanteum power & amp PCB.pdf |
Filesize: |
22.65 KB |
Downloaded: |
593 Time(s) |
Biyi
schmelfhelp
Posted: Mon Feb 02, 2015 8:49 am Post subject:
This is a great machine. I'm going to have a go at making it. Could i run this on a battery? Does it need 12v? thanks |
