CV Standard Trimmer
Page 1 of 1 [6 Posts]
El Mop
PostPosted: Wed Jan 09, 2013 11:40 am    Post subject: CV Standard Trimmer Reply with quote  Mark this post and the followings unread
Hi there!
Can I build the CV Standard with 200k for T22 instead of 220K anf
with 50k for T21 instead of 47k without getting trouble?
Thank you!
Cardinen
PostPosted: Fri Jan 11, 2013 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, no problems ! Laughing
El Mop
PostPosted: Sun Jan 13, 2013 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Tried it in LTSpice just before I read your answer
and with that I got to same result. Smile
But with what the h*** I should measure 5V +/- 0.001mV? Sad
yusynth
PostPosted: Tue Jan 15, 2013 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's 5V+/-0.001V !
For this you need a good 5000 pts or 10000 pts DVM
Yves
El Mop
PostPosted: Mon Jan 21, 2013 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, of course 0.001V. that is what I meant!
These good DVM seems to be very "good" when it comes to their prices either, sadly. Sad
KnobHell
PostPosted: Tue Jan 22, 2013 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
How much tempeture drift do you see?
I assume you warm everything up for a bit before you calibrate.
Len
