Esplora -> 2xCV + Trigger
Page 1 of 1 [8 Posts]
PostPosted: Mon Jan 07, 2013 11:07 pm    Post subject: Esplora -> 2xCV + Trigger
Subject description: Or at least that's the goal....
I got an Esplora over the weekend, and while distracting myself from a misbehaving Baby-8 Sequencer, decided to use a 2 channel 12 bit SPI DAC I had lying around (MPC4922) to use the Esplora as a CV generator.
I want each axis of the joystick to be one CV, and the rightmost button on the diamond as trigger. I intend to scale the two axes by setting the slider and clicking the top and bottom buttons on the diamond (haven't decided which is X and which is Y yet). And for future fun I'll make the fourth button change modes, indicating mode with the RGB LED at the lower right.
Even though I think this should work with just the one chip, I am still somewhat space constrained, so I glued three cheap jacks together and glued them to the board.
Then I got silly and figured that one of the targets for this is my cigarlab+ which has CV in for pitch on two oscillators, but most other control voltages are bananas, so i glued/soldered two bananas to the two CV outputs. Obviously there are grounding issues so using them will require me to plug in the 1/4" jack for the trigger, even if I don't use that trigger mode.
All this is built and planned, but not one bit of coding yet Smile. Hopefully in the next week....
Top View before jacks
 Filesize:  322.82 KB
 Viewed:  16 Time(s)
Looking down the barrel
 Filesize:  422.55 KB
 Viewed:  16 Time(s)
flying over
 Filesize:  435.03 KB
 Viewed:  17 Time(s)
and behind
 Filesize:  451.93 KB
 Viewed:  17 Time(s)
PostPosted: Tue Jan 08, 2013 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
aaand success Smile At least good enough to call done for now, I implemented all the ideas I wanted to, though they could probably be done more gracefully or perhaps in a more musically useful way.
PostPosted: Wed Jan 09, 2013 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Theory of Operation:
The Joystick controls two control voltages, one for each axis.
The slider is used in conjunction with the up and down buttons on the button pad to set the Y and X axis voltage ranges, respectively. You set the slider to some approximation of how "wide" you want the range to be, and then hit the respective X or Y axis button.
The left button changes the mode.
The right button is the trigger/gate button.
In Mode 0, the LED is red, and the right button sends a trigger out the trigger jack (10ms I believe, 5V).
In Mode 1, the LED is green, and the right button is a gate, so the trigger jack sends out 5V until you release the button.
In Mode 2, the LED is blue, but there's nothing configured to do anything... yet Smile I was thinking of firing some kind of arpeggiation, or perhaps if the slide has limited the range, let you set an offset voltage, so that the lower left isn't always 0V, 0V on the CV jacks. Or maybe simply center whatever the range is, we'll see.
Code:
 * set up to use MCP4922 on board taking over LCD slot to generate CVs
#include <Esplora.h>
#include <SPI.h>
  This array holds the last sensed state of each of the buttons
  you're reading.
  Later in the code, you'll read the button states, and compare them
  to the previous states that are stored in this array. If the two
  states are different, it means that the button was either
  pressed or released.
boolean buttonStates[4]; // only care about the 4 diamond buttons
  This array holds the names of the buttons being read.
  Later in the sketch, you'll use these names with
  the method Esplora.readButton(x), where x
  is one of these buttons.
const byte buttons[] = {
  SWITCH_RIGHT,
  SWITCH_LEFT,
  SWITCH_UP,
  SWITCH_DOWN,
const byte X = 0;
const byte Y = 1;
int scaling[2];
int mode = 0;      // values 0==trigger 1==gate, 2==uncommitted
int modes = 3;
int modeRed[] = {
  180, 0, 0
int modeGreen[] = {
  0, 140, 0
int modeBlue[] = {
  0, 0, 180
#define mySS 3
#define myTRIG 11
void setup() {
  // initialize serial communication:
  // Serial.begin(9600);
  for (byte thisButton=0; thisButton<4; thisButton++) {
    buttonStates[thisButton] = false;
  scaling[Y] = 1;
  scaling[X] = 1;
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  // Default is DIV4, or 4MHz for an AVR at 16MHz system clock
  SPI.setClockDivider(SPI_CLOCK_DIV2); // MCP4922 should be able to go up to 20MHz or even 32MHz
                                       // but half the system clock is as fast as we can go
  SPI.setDataMode(SPI_MODE0); //just to be sure.
  // alternate SS
  pinMode(mySS, OUTPUT);
  digitalWrite(mySS, HIGH);
  pinMode(myTRIG, OUTPUT);
  digitalWrite(myTRIG, LOW);
  modeLED(mode);
  //delay(20);  // setup time??
void loop() {
  // Iterate through all the buttons:
    boolean lastState = buttonStates[thisButton];
    boolean newState = Esplora.readButton(buttons[thisButton]);
    // if button, do action
    if (lastState != newState) {
      if (!newState) { // Button press down; normally high
        switch (thisButton) {
          case 0:  do_trigger(newState);
                    break;
          case 1:  change_mode();
                    break;
          case 2:  scale(Y);
                    break;
          case 3:  scale(X);
                    break;
      } else if ((mode == 1) && (thisButton == 0) && newState) {
    // Store the new button state, so you can sense a difference later:
    buttonStates[thisButton] = newState;
  // read X & Y from Joystick
  // joystick goes from -512 to +512, center is 0
  // the direction is opposite expectations, hence the - instead of +
  int xAxis = ((512 - Esplora.readJoystickX()) / scaling[X]) - 1;
  int yAxis = ((512 - Esplora.readJoystickY()) / scaling[Y]) - 1;
  if (xAxis<0) {
    xAxis = 0;
  if (yAxis<0) {
    yAxis = 0;
  // write X & Y to DAC
  doDAC(X, xAxis);
  delay(10); // give  some time to settle, may not be necessary
  doDAC(Y, yAxis);
void do_trigger(boolean state) {
  if (mode == 0) {
    digitalWrite(myTRIG, HIGH);
    delay(10);
    delay(10);
  } else if ((mode == 1) && (!state)) {
    delay(10);
  } else if ((mode == 1) && (state)) {
    delay(10);
void change_mode() {
  mode = (mode + 1) % modes;
  modeLED(mode);
void scale(int axis) {
  // note that slider high value is to the left, we want the reverse behavior
  int slider = Esplora.readSlider();
  if (slider > 1023) {
    slider = 1023;
  scaling[axis] = 1024 / (1024 - slider);
  //Serial.print("Slider: ");
  //Serial.println(Esplora.readSlider());
  //Serial.print("Scale factor: ");
  //Serial.println(scaling[axis]);
void doDAC(byte port, int value) {
  // port 0 == A on DAC, port 1 == B on DAC
  // value is 1-1024, needs to be scaled up *4 but limited to 4095
  value *= 4;
  //Serial.print("port: ");
  //Serial.print(port);
  //Serial.print("  value: ");
  //Serial.println(value);
  switch (port) {
    case 0: value |= 0x3000; //select channel A, gain = 1
          break;
    case 1: value |= 0xB000; // select channel B, gain = 1
          break;
  digitalWrite(mySS, LOW); // manual slave select
  SPI.transfer(highByte(value));
  SPI.transfer(lowByte(value));
void modeLED(int mode) {
  Esplora.writeRGB(modeRed[mode], modeGreen[mode], modeBlue[mode]);
 Filesize:  13.26 KB
 Viewed:  19 Time(s)
PostPosted: Wed Jan 09, 2013 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not posting stripboard because 1) mine is a bastard thing and 2) I don't have a stripboard editor that I like and don't have patience to go find one right now. The important thing is that the two 10-pin pin headers that mate with the Esplora have 20 columns between them (not inclusive), so they'd be column 1 and column 22, and that nothing of either is used except for the 3rd and 4th pins of the right header.
bubzy
Audio files: 47
PostPosted: Thu Jan 10, 2013 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
looks cool man, the video doesnt work tho :/
_Richard_ Smile
Audio files: 254
PostPosted: Thu Jan 10, 2013 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
video works fine for me Cool
http://www.acidtrash.com/
PostPosted: Thu Jan 10, 2013 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
I wonder what's up with the video, it works here too.
PostPosted: Fri Jan 25, 2013 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Correction to the schematic, VERY IMPORTANT
PUT 1K OUTPUT RESISTORS ON THOSE JACKS!
I fried my D11 output when attempting this with my modular rather than my cigarlab.
I've hacked a different solution onto mine, but don't make the same mistake Smile
Niio2
