Any simple bass drum schematic? or snare?
Page 1 of 1 [15 Posts]
wahoah
PostPosted: Wed Jan 30, 2013 5:53 pm    Post subject: Any simple bass drum schematic? or snare? Reply with quote  Mark this post and the followings unread
Hi!
Ive been serching for a simple bass drum schematic and havent find anything, a snare could be great too or a hi hat
anyone have one?
-minus-
PostPosted: Wed Jan 30, 2013 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. I'd suggest the Korg Monotribe drums. They are transistor based. I have recently built the 3 voices on pieces of stripboard. They are quite straight forward and will run on 9V. You'll need a noise source too. I made a simple two transistor white noise generator which works fine. Breadboard the circuits first as I found by fiddling with the values I got a better result for what I wanted. I also added a open hat sound. Here's the schematic...
monotribe_schematic.pdf
 Filename:  monotribe_schematic.pdf
 Filesize:  56.41 KB
 Downloaded:  142 Time(s)
wahoah
PostPosted: Wed Jan 30, 2013 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
what i should do with the IC on the first part of the schematic?
im guessing that mi input (the part that says BD) will be like a Control voltage input?
And could i use a 2n2222 transistor?
 Filesize:  32 KB
 Viewed:  1864 Time(s)
-minus-
PostPosted: Wed Jan 30, 2013 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I did with the input is this. I removed that section you circled on the schematic and replace it with a diode, 100K resistor to ground, and 0.1uF cap. This means I can trigger the drum to fire using a gate signal of any length. I am using these drums in my logic synth/Lunetta so it is handy to be able to trigger the drum from a logic signal..
I used 2N3904's in mine but a 2N222 should work as well. Also, I added the output transistor section to the right of the schematic from Korg. I left off the PORT section and just added everything on the right of that. This gave the kick drum heaps more BOOOOM. Oh, and I used a 1K pot going to Ground where Korg have BD DECAY labelled. This gives the kick drum adjustable decay to a point of self oscillation.
 Filesize:  86.46 KB
 Viewed:  39 Time(s)
-minus-
PostPosted: Wed Jan 30, 2013 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I should have done this before. Mine looks like this:
 Filesize:  85.54 KB
 Viewed:  95 Time(s)
Tony Deff
PostPosted: Sun Feb 03, 2013 10:34 am    Post subject: Re: Any simple bass drum schematic? or snare? Reply with quote  Mark this post and the followings unread
wahoah wrote:
Hi!
I've been searching for a simple bass drum schematic and haven't found anything; a snare could be great too, or a hi hat.
Anyone have one?
Aloha, Wahoah,
I built a very passable set of 8, way-back in the previous millenium, from a design published in Practical Electronics here in the 51st State.
I may still have it, but don't fancy re-drawing the schematics from the original stone-tablet carvings.
Whilst quickly looking to see if was archived on-line, I came across this set of Carillon (The bells! The bells!)
Everyday Practical Electronics 2008 PDF (scroll down to page 35).
Hells bells.
-minus-
PostPosted: Mon Feb 04, 2013 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thers some reasonabell Laughing chimes to be had from Ken Stone's Chime Simulator...
http://www.cgs.synth.net/modules/cgs19_chime.html
I built this and the bells are quite convincing although not easily retuned.
Or for a kick sound you could try Eric Archers Mini Space Rockers...
http://ericarcher.net/devices/mini-space-rockers/
I built this too. There are three caps you can experiment with to get a variety of tones. This is a simple circuit and easy to breadboard and play around with. There are some sound files on Eric's site with various cap sizes and the sounds they create. I couldn't make my mind up on the caps so I used three twelve position rotary switches... giving me... 12 X 12 X 12 variations Confused
Audio files: 51
PostPosted: Mon Feb 04, 2013 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget Thomas Henry's MPS. It is a lot of kit for 1 drum, but it definitely allows for everything. 3partials/RM/Noise filter.
It's a very small board too, laid out by yours truly! Cool Embarassed
We would lose our friends.
So,.........
wahoah
PostPosted: Thu Feb 07, 2013 9:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive just breadboarded the Bass Drum from the monotribe korg, i like it but i need a little more bass and deeeper sound
any recomendations?
PostPosted: Thu Feb 07, 2013 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/phpbb-files/kick_and_snare_652.mp3
That's from 808 and snare stripboards from here:
http://electro-music.com/forum/topic-37646.html&postorder=asc
http://electro-music.com/forum/viewtopic.php?highlight=808+snare+stripboard&t=45134
-minus-
PostPosted: Thu Feb 07, 2013 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
any recomendations?
Try a few different transistors, even of the same type. I replaced the quite a bit until I found one I liked. Have you used a decay pot? That will give it more boom. The other option is to try a more complex circuit like the 808. You'll need a bipolar power supply to run it though.
wahoah
PostPosted: Thu Feb 14, 2013 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
-minus- wrote:
any recomendations?
im not 100% shure of the location of that decay pot
i have a drawing right here, its right where i placed?
 Filesize:  53.49 KB
 Viewed:  30 Time(s)
-minus-
PostPosted: Thu Feb 14, 2013 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that is correct. Is it having no effect for you?
KRS1972
PostPosted: Thu Feb 28, 2013 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello !
have you seen this topic ?
http://electro-music.com/forum/topic-28447.html
I build this one, and it is a great sounding bass drum.
grt,
Chris
EATyourGuitar
PostPosted: Wed Mar 06, 2013 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
what you want is a simple sine VCO and a monostable source like a 555 RC lowpass'd to get a decay envelope. your envelope controls the pitch of the sine wave. you can skip the VCA if you just high pass the bass drum sound right around 100hz. that should give you a nice fade out from a single envelope.
