Roland JP8000 major distortion in all outputs
Page 1 of 1 [2 Posts]
Parallel Worlds
PostPosted: Mon Jan 28, 2013 6:41 am    Post subject: Roland JP8000 major distortion in all outputs Reply with quote  Mark this post and the followings unread
hi,
i have a Roland JP8000 synth that i am using for the past 13 years...
suddenly, few days ago, it started appearing major distortion in both stereo outputs and in its phone outputs.
the distortion is very loud and annoying. sometimes it comes and goes.
so, for short times, the synth plays fine and then the distortion fades in slowly....
also, during the times when the synth plays fine, (while before it sounded distorted), usually the former distortion fades out slowly until the synth sounds clean....
btw, two years ago, i had changed its battery and re-calibrated its ribbon and bender.
i opened the synth up and could not see any problem in ribbon cable connections. although i cannot check the solder joints if any are dry etc.....
any idea what this distortion could be?
thanks in advance for your help!
best regards, Smile
Bakis.
www.parallel-worlds-music.com
www.facebook.com/pages/parallelworldsmusic
https://dinrecords.bandcamp.com/
abyzz
PostPosted: Fri Feb 15, 2013 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mine has suffered a similar fate tonight - have you had any luck in fixing it or knowing what is wrong?
