Radio played
Page 1 of 1 [5 Posts]
Audio files: 337
PostPosted: Sun Jan 27, 2013 4:08 pm    Post subject: Radio played
Subject description: instrument
...so I had this old radio/mini boombox/cassette player which stopped working somewhat. It was still picking up the radio so I have used it as such on and off over the years... but I was never able to "play" the radio properly because the tuning dial was awkward... Hence I rehoused it in a smaller package (which happens to be my ex-router (which still works but is now without a house)) - - the big white wheel is directly connected to the tuning inside, and the other big knob is for the volume, which was given a new (old recycled) pot, and the antenna is connected to the touch point. It also has a built in mic with a rudimentary limiter on it, which can be used for feedback effects... all in all a nice little versatile hummer/noiser/feedbacker Smile
Find attached a little sound sample from the virgin journey, effected through a korg mini kaoss pad.
Rehoused noise source stroke ground loop hummer stroke feedback device stroke heart attack device...
 Filesize:  680.93 KB
 Viewed:  386 Time(s)
playradio.mp3
Playable radio through Mini-kaoss-pad effects.
 Filename:  playradio.mp3
 Filesize:  2.32 MB
 Downloaded:  853 Time(s)
Muied Lumens Base Star
Audio files: 337
PostPosted: Mon Jan 28, 2013 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ended up doing a jam using this thing last night... time flew and suddenly it had been almost an hour. This is an unedited recording of the live feed.
Edit: This post had a file attached - which turned out to be a limited edition... New version coming. Wink
Audio files: 213
G2 patch files: 319
PostPosted: Mon Jan 28, 2013 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quite nice!
Audio files: 337
PostPosted: Tue Jan 29, 2013 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quite nice!
Smile Thank you.
Audio files: 337
PostPosted: Fri Feb 22, 2013 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
...which ended up here http://electro-music.com/forum/post-379230.html#379230
Hope you enjoy. Smile
