bod
Posted: Thu Mar 14, 2013 12:04 pm Post subject:
9v to 15v DC step up convertor Subject description: Tr 606 style |
Evening folks,
I'm working on a synth project that needs a 15vdc (positive only) supply from a 9vdc input. The tr 606 uses such a technique but the MC102c was (I believe) a custom model for Roland and goes for £49 on eBay these days.
Linear technologies and a host of other suppliers have a plethora of such chips but I was wondering if anyone has any recommendations for synth use at all?
Bod |
johncronan
Posted: Thu Mar 14, 2013 11:16 pm Post subject:
Personally, nothing fills me with dread more than the prospect of switch mode power supply design. I've always stuck with linear, mostly because I fear (perhaps irrationally) what the EMI might do to my circuit.
Since you have no choice, my advice would be to buy something ready made. Maybe this (but it depends on how much power you need):
http://www.digikey.com/product-detail/en/VWRBS2-D12-S15-SIP/102-1512-ND/1558907
Otherwise... someone on synth-diy recently recommended the Simple Switcher line, so that's something. I would probably go with the adjustable version of the LM2585.
Hope that helps! -John |
bod
Posted: Sun Mar 17, 2013 9:11 am Post subject:
Thanks John, I'll have a look through them. To be honest I agree, I prefer linear supplies too. But whilst discussing how ridiculously expensive some old analogue gear has become, I have taken up the challenge set by a friend to build a clone 606 for under £100!
There's no way I can do the sequencer for that price as well so it's just going to be midi and externally trigger-able. The psu is the problem, these up convertors can be expensive, but then 15vdc wall wart psu's are less common than 9 or 12v, and just as expensive or more so.
More research required I think!  |
stewpye
Joined: Apr 30, 2009 Posts: 47 Location: Brisbane, Australia
Posted: Wed Mar 27, 2013 7:28 pm Post subject:
I'd probably either use a 15VDC Meanwell switchmode plugpack, or an 18V plugpack with a 15 volt linear regulator if you're worried about noise.
Regards,
Stewart. |
johncronan
Posted: Wed Mar 27, 2013 11:21 pm Post subject:
I was assuming as part of the question that it needs to be from a 9 V DC input for some reason.
But otherwise, yeah, listen to Stewart! |
moosapotamus
Joined: May 11, 2007 Posts: 96 Location: New Hampshire USA
Posted: Fri Mar 29, 2013 11:43 am Post subject:
In a recent discussion at DIYSB about the LT1054, PRR pointed to this DC-DC converter circuit...
http://www.pololu.com/catalog/product/799
Looks like you can find similar circuits on ebay for even less money.
Could probably DIY too, if you know what makes it (not) tick.
~ Charlie _________________ moosapotamus.net
"I tend to like anything that I think sounds good" |
