PCB offer: Thomas Henry's 555-VCO
Page 5 of 5 [116 Posts]
Goto page: Previous 1, 2, 3, 4, 5
lucid
PostPosted: Mon Mar 04, 2013 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
Do you have 2 150Ks?
Idea this
thanks
logicgate
PostPosted: Mon Mar 04, 2013 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello guys!
Can I get away by using 1,87K 3500ppm tempcos for this project???
Cheers!
Gaetano_AU
PostPosted: Tue Mar 05, 2013 3:59 am    Post subject:  Boards Arrived Matthias, nicely packed, thanks :) Reply with quote  Mark this post and the followings unread
Boards Arrived Matthias, nicely packed, thanks Smile
PostPosted: Tue Mar 05, 2013 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
logicgate wrote:
Hello guys!
Cheers!
w/o doing the maths: i don't believe you will achieve the 1V/oct using the 1k87...
fonitronik at
PostPosted: Tue Mar 05, 2013 2:18 pm    Post subject: payment details Reply with quote  Mark this post and the followings unread
i sent out PMs/emails to all who ordered PCBs/panels. please check you PM's, i am missing the response of quite a few people.
fonitronik at
LektroiD
PostPosted: Wed Mar 06, 2013 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm assuming the farnell pots I linked won't fit this project?
Any other sources (that are not wildly expensive)?
My tunes available here
(check out the new Electro-Funk LP)
PostPosted: Wed Mar 06, 2013 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Banzai seem quite expensive for their pots. Would this fit?
http://uk.farnell.com/jsp/search/productdetail.jsp?id=1191742&_requestid=24555
they would fit the footprint, buuuut:
they are not high enough.
farnell offers other alps with a longer shaft, but alas, these are D-shaft, too. and D-shaft would not be cool with the LFO, since not all potentiometers are mounted with the same orientation...
BTW i built two modules with the alps (get them cheap here in germany , and with a full shaft), and they don't have enough tension IMHO. doesn't feel right to me.
fonitronik at
PostPosted: Wed Mar 13, 2013 2:42 am    Post subject: Re: payment details Reply with quote  Mark this post and the followings unread
fonitronik at
ungleichklang
PostPosted: Wed Mar 13, 2013 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry Mathias, my 4 boards arrived, all is fine
btw. do I really have to use tempco's??
My new blogspot: http://ungleichklang.blogspot.com
My Youtube-Channel: http://www.youtube.com/user/ungleichklang
My old google-site: https://sites.google.com/site/ungleichklang/home/s-diy
Linux Musician
PostPosted: Thu Mar 14, 2013 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
the tempco's are to reduce drift due to temperature changes. this gets more important the longer the takes are you recording, and if you are interested in more precise tuning between the tracks.
fonitronik at
diablojoy
PostPosted: Fri Mar 15, 2013 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
boards received in OZ all good
thanks again Matthias.
ask where the hell am I
as good an answer as any
jp1971
PostPosted: Wed Mar 20, 2013 9:55 am    Post subject: PCB offer: Thomas Henry's 555-VCO Reply with quote  Mark this post and the followings unread
Sorry for coming to this thread late. Are there any PCBs left? If so, I would like to order:
1x circuit PCB
1x eurorack PCB
1x front panel
Thanks,
jp1971
PostPosted: Thu Mar 21, 2013 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
there are quite a few open orders, and i actually wanted to keep a few spares just in case something gets lost in the mail. but i will put you on the waiting list.
fonitronik at
doobedy
PostPosted: Fri Mar 22, 2013 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Man I just noticed the prototype had an LFO switch and LED. I wish those had made it to the panel as well.
Is that just a switch changing capacitor values? How is the LED done? Not that I see room on the panels to fit anything on there. I was thinking of a wave folder to go between my two VCOS, maybe I could add an LED and LFO switch to that as a custom panel.
Did TH specifically ask you not expand his circuit in any way?
modulardoom
PostPosted: Mon Apr 01, 2013 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
if it would be still possible i would like to order
1 circuit pcb
1 eurorack pcb
1 front panel
Constantin
PostPosted: Sun Apr 07, 2013 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
If there are still some pcbs available, I would be in for
4 circuit PCB
thanks
Constantin
Niio1
