  Muied Lumens Frequencies
Arduino - MIDI - CV
Page 1 of 1 [7 Posts]
droffset
PostPosted: Mon Apr 12, 2010 11:44 pm    Post subject: Arduino - MIDI - CV Reply with quote  Mark this post and the followings unread
Found this interesting take on doing MIDI to CV via a PWM setup. I don't read Japanese but the schematics and code are there.
http://sites.google.com/site/diyanalogsynth/plug-in/midi2cv
Also Colin seems to have a way to do MIDI-CV via his MIDIVox shield. I have one coming in the mail so it's a pretty intriguing prospect.
http://www.narbotic.com/files/0feee87cca5f55bc7963cdb01151aba4-8.html
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
Skellz
PostPosted: Tue Apr 13, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you seen this ? http://andregoncalves.info/addac/
Looks amazing would love to have a few of those modules
droffset
PostPosted: Thu Apr 15, 2010 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
That does look cool. Thanks, I just signed up on his mailing list. Smile
hanley
PostPosted: Thu Apr 22, 2010 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
another here
seem simple enough
http://registeringdomainnamesismorefunthandoingrealwork.com/blogs/?p=51
no neat schematic to go with it though
tonysnail
PostPosted: Tue Mar 19, 2013 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a variation on this - an arduino CV envelope generator.. It takes MIDI gate input and creates an ADSR envelope, passing it as a 0-5v CV..
It reads MIDI CC values and uses this to control the envelope parameters.
The idea being to replace the digital filter within a synth in Reaktor with a real live one..
I also did it with an 8 bit R2R network because I wasn't happy with the PWM output.
Will post the source code if anyone's interested!
Carl
Skellz
PostPosted: Tue Mar 19, 2013 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Post it i would love to see your code
tonysnail
PostPosted: Tue Mar 19, 2013 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure!
It needs an R2R network across pins 8-13, and the highest bit on pin 7.
MIDI CC values 5-8 are used to control the ADSR parameters - these are read by a MIDI in (opto) circuit at the RX pin.
Use it to turn an otherwise lifeless plugin synth into a living, breathing, analog filtered beast!
Code:
// Arduino CV envelope generator - working version with MIDI shield and CV output
// This code generates a VCF envelope and sends it to an R2R network out of PORTB (pins 8-13) and pin 7
// We now need to read CC values from Reaktor and calculate ADSRs from the MIDI inputs
// attack - 0.4 is getting quite fast, 0.01 is quite slow
// 127 / 250 = 0.508 .. 1 / 250 = 0.004 - this seems a good translation from midi to adsr values
// CC values:
// Attack: CC #5
// Decay: CC #5
// Sustain: CC #5
// Release: CC #5
// (c) Carl Hudson -  www.carlhudson.co.uk
// Free to copy source code so long as Author is mentioned!
#include <MIDI>
#include <avr>
// the size of the attack and decay wavetables
#define ATTACK_SIZE 2024
#define ATTACK2_SIZE 2025
#define DECAY_SIZE 2073
// the calibration value is a number that divides the rate we read through the attack and decay wavetables
#define ATTACK_CC_CALIBRATION 60
#define DECAY_CC_CALIBRATION 60
#define RELEASE_CC_CALIBRATION 60
int debug=0;
int velocityFlag = 0;
int testcount=0;
int highVal=0;
int k=0;
float tablePos = 0;
float attackRate = 0;
float decayRate = 0;
int sustainRate = 0;
int MIDIval = 0;
int gate = 0;
int attackCC = 40;
int decayCC = 64;
int sustainCC = 64;
int releaseCC = 127;
float MIDIconv = 0;
float releaseRate = 10;
int decayCalc = 0;
int releaseCalc = 0;
int envelopePos=0;
int testCounter=0;
int noteSwitch = 0;
prog_char attackTable[ATTACK_SIZE] PROGMEM = { 0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  34,  34,  34,  34,  34,  34,  34,  34,  34,  34,  34,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  36,  36,  36,  36,  36,  36,  36,  36,  36,  36,  36,  37,  37,  37,  37,  37,  37,  37,  37,  37,  37,  37,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  39,  39,  39,  39,  39,  39,  39,  39,  39,  39,  39,  40,  40,  40,  40,  40,  40,  40,  40,  40,  40,  40,  41,  41,  41,  41,  41,  41,  41,  41,  41,  41,  41,  42,  42,  42,  42,  42,  42,  42,  42,  42,  42,  42,  43,  43,  43,  43,  43,  43,  43,  43,  43,  43,  43,  44,  44,  44,  44,  44,  44,  44,  44,  44,  44,  45,  45,  45,  45,  45,  45,  45,  45,  45,  45,  45,  46,  46,  46,  46,  46,  46,  46,  46,  46,  46,  46,  47,  47,  47,  47,  47,  47,  47,  47,  47,  47,  48,  48,  48,  48,  48,  48,  48,  48,  48,  48,  48,  49,  49,  49,  49,  49,  49,  49,  49,  49,  49,  49,  50,  50,  50,  50,  50,  50,  50,  50,  50,  50,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  52,  52,  52,  52,  52,  52,  52,  52,  52,  52,  53,  53,  53,  53,  53,  53,  53,  53,  53,  53,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  55,  55,  55,  55,  55,  55,  55,  55,  55,  55,  56,  56,  56,  56,  56,  56,  56,  56,  56,  56,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  58,  58,  58,  58,  58,  58,  58,  58,  58,  58,  59,  59,  59,  59,  59,  59,  59,  59,  59,  59,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  61,  61,  61,  61,  61,  61,  61,  61,  61,  61,  62,  62,  62,  62,  62,  62,  62,  62,  62,  62,  63,  63,  63,  63,  63,  63,  63,  63,  63,  63,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  65,  65,  65,  65,  65,  65,  65,  65,  65,  65,  66,  66,  66,  66,  66,  66,  66,  66,  66,  66,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  68,  68,  68,  68,  68,  68,  68,  68,  68,  68,  69,  69,  69,  69,  69,  69,  69,  69,  69,  69,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  71,  71,  71,  71,  71,  71,  71,  71,  71,  71,  72,  72,  72,  72,  72,  72,  72,  72,  72,  72,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  74,  74,  74,  74,  74,  74,  74,  74,  74,  74,  75,  75,  75,  75,  75,  75,  75,  75,  75,  75,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  77,  77,  77,  77,  77,  77,  77,  77,  77,  77,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  80,  80,  80,  80,  80,  80,  80,  80,  80,  80,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  83,  83,  83,  83,  83,  83,  83,  83,  83,  83,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127, };
prog_char decayTable[DECAY_SIZE] PROGMEM = { 127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  127,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  83,  83,  83,  83,  83,  83,  83,  83,  83,  83,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  80,  80,  80,  80,  80,  80,  80,  80,  80,  80,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  77,  77,  77,  77,  77,  77,  77,  77,  77,  77,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  75,  75,  75,  75,  75,  75,  75,  75,  75,  75,  74,  74,  74,  74,  74,  74,  74,  74,  74,  74,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  72,  72,  72,  72,  72,  72,  72,  72,  72,  72,  71,  71,  71,  71,  71,  71,  71,  71,  71,  71,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  69,  69,  69,  69,  69,  69,  69,  69,  69,  69,  68,  68,  68,  68,  68,  68,  68,  68,  68,  68,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  66,  66,  66,  66,  66,  66,  66,  66,  66,  66,  65,  65,  65,  65,  65,  65,  65,  65,  65,  65,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  63,  63,  63,  63,  63,  63,  63,  63,  63,  63,  62,  62,  62,  62,  62,  62,  62,  62,  62,  62,  61,  61,  61,  61,  61,  61,  61,  61,  61,  61,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  59,  59,  59,  59,  59,  59,  59,  59,  59,  59,  58,  58,  58,  58,  58,  58,  58,  58,  58,  58,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  56,  56,  56,  56,  56,  56,  56,  56,  56,  56,  55,  55,  55,  55,  55,  55,  55,  55,  55,  55,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  53,  53,  53,  53,  53,  53,  53,  53,  53,  53,  52,  52,  52,  52,  52,  52,  52,  52,  52,  52,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  50,  50,  50,  50,  50,  50,  50,  50,  50,  50,  49,  49,  49,  49,  49,  49,  49,  49,  49,  49,  49,  48,  48,  48,  48,  48,  48,  48,  48,  48,  48,  48,  47,  47,  47,  47,  47,  47,  47,  47,  47,  47,  46,  46,  46,  46,  46,  46,  46,  46,  46,  46,  46,  45,  45,  45,  45,  45,  45,  45,  45,  45,  45,  45,  44,  44,  44,  44,  44,  44,  44,  44,  44,  44,  43,  43,  43,  43,  43,  43,  43,  43,  43,  43,  43,  42,  42,  42,  42,  42,  42,  42,  42,  42,  42,  42,  41,  41,  41,  41,  41,  41,  41,  41,  41,  41,  41,  40,  40,  40,  40,  40,  40,  40,  40,  40,  40,  40,  39,  39,  39,  39,  39,  39,  39,  39,  39,  39,  39,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  37,  37,  37,  37,  37,  37,  37,  37,  37,  37,  37,  36,  36,  36,  36,  36,  36,  36,  36,  36,  36,  36,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  34,  34,  34,  34,  34,  34,  34,  34,  34,  34,  34,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0, };
prog_char attack2Table[ATTACK2_SIZE] PROGMEM = { 2,  2,  2,  2,  2,  2,  3,  3,  3,  3,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  4,  5,  5,  5,  5,  5,  5,  5,  5,  5,  5,  6,  6,  6,  6,  6,  6,  6,  6,  6,  6,  7,  7,  7,  7,  7,  7,  7,  7,  7,  7,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  8,  9,  9,  9,  9,  9,  9,  9,  9,  9,  9,  10,  10,  10,  10,  10,  10,  10,  10,  10,  10,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  11,  12,  12,  12,  12,  12,  12,  12,  12,  12,  12,  13,  13,  13,  13,  13,  13,  13,  13,  13,  13,  14,  14,  14,  14,  14,  14,  14,  14,  14,  14,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  15,  16,  16,  16,  16,  16,  16,  16,  16,  16,  16,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  17,  18,  18,  18,  18,  18,  18,  18,  18,  18,  18,  19,  19,  19,  19,  19,  19,  19,  19,  19,  19,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  21,  21,  21,  21,  21,  21,  21,  21,  21,  21,  22,  22,  22,  22,  22,  22,  22,  22,  22,  22,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  23,  24,  24,  24,  24,  24,  24,  24,  24,  24,  24,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  25,  26,  26,  26,  26,  26,  26,  26,  26,  26,  26,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  27,  28,  28,  28,  28,  28,  28,  28,  28,  28,  28,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  29,  30,  30,  30,  30,  30,  30,  30,  30,  30,  30,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  32,  33,  33,  33,  33,  33,  33,  33,  33,  33,  33,  34,  34,  34,  34,  34,  34,  34,  34,  34,  34,  34,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  35,  36,  36,  36,  36,  36,  36,  36,  36,  36,  36,  37,  37,  37,  37,  37,  37,  37,  37,  37,  37,  37,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  38,  39,  39,  39,  39,  39,  39,  39,  39,  39,  39,  39,  40,  40,  40,  40,  40,  40,  40,  40,  40,  40,  41,  41,  41,  41,  41,  41,  41,  41,  41,  41,  41,  42,  42,  42,  42,  42,  42,  42,  42,  42,  42,  42,  43,  43,  43,  43,  43,  43,  43,  43,  43,  43,  43,  44,  44,  44,  44,  44,  44,  44,  44,  44,  44,  44,  45,  45,  45,  45,  45,  45,  45,  45,  45,  45,  45,  46,  46,  46,  46,  46,  46,  46,  46,  46,  46,  46,  47,  47,  47,  47,  47,  47,  47,  47,  47,  47,  47,  48,  48,  48,  48,  48,  48,  48,  48,  48,  48,  48,  49,  49,  49,  49,  49,  49,  49,  49,  49,  49,  49,  50,  50,  50,  50,  50,  50,  50,  50,  50,  50,  50,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  51,  52,  52,  52,  52,  52,  52,  52,  52,  52,  52,  52,  53,  53,  53,  53,  53,  53,  53,  53,  53,  53,  53,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  54,  55,  55,  55,  55,  55,  55,  55,  55,  55,  55,  55,  56,  56,  56,  56,  56,  56,  56,  56,  56,  56,  56,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  57,  58,  58,  58,  58,  58,  58,  58,  58,  58,  58,  58,  59,  59,  59,  59,  59,  59,  59,  59,  59,  59,  59,  59,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  60,  61,  61,  61,  61,  61,  61,  61,  61,  61,  61,  61,  62,  62,  62,  62,  62,  62,  62,  62,  62,  62,  62,  62,  63,  63,  63,  63,  63,  63,  63,  63,  63,  63,  63,  63,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  64,  65,  65,  65,  65,  65,  65,  65,  65,  65,  65,  65,  65,  66,  66,  66,  66,  66,  66,  66,  66,  66,  66,  66,  66,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  67,  68,  68,  68,  68,  68,  68,  68,  68,  68,  68,  68,  68,  69,  69,  69,  69,  69,  69,  69,  69,  69,  69,  69,  69,  69,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  70,  71,  71,  71,  71,  71,  71,  71,  71,  71,  71,  71,  71,  72,  72,  72,  72,  72,  72,  72,  72,  72,  72,  72,  72,  72,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  73,  74,  74,  74,  74,  74,  74,  74,  74,  74,  74,  74,  74,  74,  75,  75,  75,  75,  75,  75,  75,  75,  75,  75,  75,  75,  75,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  76,  77,  77,  77,  77,  77,  77,  77,  77,  77,  77,  77,  77,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  78,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  79,  80,  80,  80,  80,  80,  80,  80,  80,  80,  80,  80,  80,  80,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  81,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  82,  83,  83,  83,  83,  83,  83,  83,  83,  83,  83,  83,  83,  83,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  84,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  85,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  86,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  87,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  88,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  89,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  90,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  92,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  93,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  94,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  95,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  96,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  97,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  98,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  99,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  100,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  101,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  102,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  103,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  104,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  105,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  106,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  107,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  108,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  109,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  110,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  111,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  112,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  113,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  114,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  115,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  116,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  117,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  118,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  119,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  120,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  121,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  122,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  123,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  124,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  125,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  126,  127,  127,  127,  127,  127, };
void setup() {
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(4, OUTPUT);
  tablePos=4;
  k=0;
 if (debug==1) {
  Serial.begin(9600);
 } else {
  MIDI.begin(1);
  MIDI.setHandleNoteOn(MIDInoteOn);
  MIDI.setHandleNoteOff(MIDInoteOff);
  MIDI.setHandleControlChange(MIDIcontrolChange);
void flashLED() {
  digitalWrite(13, HIGH);
  delay(5);
  digitalWrite(13, LOW);
  delay(5);
void MIDInoteOn(byte channel, byte note, byte velocity) {
 if (velocity>0) {
   velocityFlag=0;
 } else {
   velocityFlag=1;
switch (velocityFlag){
    case(0):
        envelopePos = 0;
        k=0;
        tablePos=0;
        gate=1;
    break;
    case(1):
        MIDInoteOff(1, 50, 50);
        //flashLED();
    break;
void MIDInoteOff(byte channel, byte note, byte velocity) {
    envelopePos = 3;
    k=0;
    tablePos=0;
    gate=0;
    //flashLED();
void MIDIcontrolChange(byte channel, byte number, byte value) {
  switch ((int) number) {
    case (5):      // Attack   [CC 5]
      attackCC = (int) value;
    break;
    case (6):      // Decay   [CC 6]
      decayCC = (int) value;
    break;
    case (7):      // Sustain   [CC 7]
      sustainCC = (int) value;
    break;
    case (8):      // Release   [CC 8]
      releaseCC = (int) value;
    break;
void sendCV(int MIDIval) {
  // send CV voltage to pins
  MIDIval=127-MIDIval;
  highVal=LOW;
  if (MIDIval>63) highVal=HIGH;
  PORTB = MIDIval;
  digitalWrite(7, highVal);
 if (debug==1) {
  Serial.print("env: ");
  switch (envelopePos) {
    case(0):
      Serial.print("attack");
    break;
     case(1):
      Serial.print("decay");
    break;
     case(2):
      Serial.print("sustain");
    break;
     case(3):
      Serial.print("release");
    break;
  Serial.print("  |  CV:");
  Serial.println(MIDIval);
void loop() {
  if (gate==1) {
  } else {
  // test code
  testcount++;
  if (testcount==50) MIDInoteOn(1, 50, 50);
  if (testcount==100) MIDInoteOn(1, 50, 50);
  if (testcount==10000) MIDInoteOff(1, 50, 50);
  if (testcount==10050) MIDInoteOff(1, 50, 50);
  if (testcount==25000) testcount=0;
  if (debug!=1) {
     MIDI.read();
  if ((attackCC==0) && (envelopePos==0)) envelopePos=1;
  if (decayRate==0) decayRate=0.0001;
  if ((releaseCC==0) && (envelopePos==3)) envelopePos=4;
  attackRate = (127-(float) attackCC) / ATTACK_CC_CALIBRATION;
  decayRate = (127-(float) decayCC) / DECAY_CC_CALIBRATION;
  sustainRate = sustainCC;
  releaseRate = (127-(float) releaseCC) / RELEASE_CC_CALIBRATION;
  int MIDIval=0;
   case 0:                                          // attack
    MIDIval = pgm_read_byte_near(attack2Table + k);
    tablePos=tablePos+attackRate;
    k = (int) tablePos;
      if (k>ATTACK2_SIZE) {
        k=0;
        tablePos=0;
        envelopePos++;
      //if (attackCC==127) MIDIval = 127;
  break;
   case 1:                                          // decay
   decayCalc = 127 - sustainRate;
    MIDIval = (pgm_read_byte_near(decayTable + k));
    MIDIval = (((float) MIDIval/127)*(float) decayCalc) + (127-(float) decayCalc);
    tablePos=tablePos+decayRate;
    k = (int) tablePos;
     if (k>DECAY_SIZE) {
       k=0;
       tablePos=0;
       envelopePos++;
  break;
   case 2:                                           // sustain
    MIDIval = sustainRate;
     // test code
     testCounter++;
     if (testCounter==56) {
       k=0;
       tablePos=0;
       testCounter=0;
       envelopePos++;
  break;
   case 3:                                           // release
  releaseCalc = sustainRate -(127-sustainRate);
    MIDIconv = ((float) MIDIval / 127) * sustainRate;
    MIDIval = (int) MIDIconv;
            if (MIDIval<0>DECAY_SIZE) {
                k=0;
                tablePos=0;
                envelopePos = 4;
   break;
  case 4:          // holding MIDI note off
    MIDIval = 0;
  sendCV(MIDIval);
  tablePos=tablePos+pitch;
  k = tablePos;
  if (k>1023) {
    k=0;
    tablePos=0;
  // calculate upper bit (Pin 7)
