Minimoog filter started having problems
Page 1 of 1 [2 Posts]
LetterBeacon
PostPosted: Tue May 07, 2013 3:18 pm    Post subject: Minimoog filter started having problems Reply with quote  Mark this post and the followings unread
I built Yusynth's Minimoog filter about four years ago, and use it often.
I turned my modular on the other day and it had stopped passing signal. Somehow, the wire that connects the Cutoff pot with ground has come loose. I soldered it back, turned it on, and still nothing.
I fed a 0-6vpp saw tooth from my ARP Odyssey oscillator into the filter.
The signal at the input (pin 6) of the TL072 I read at -6 to -3vpp and there's no signal at the output (pin 7).
I've swapped out the TL072, but I still have the same problem, so it's not the opamp.
If someone could shed some light on this problem, that would be great!
Thanks,
Matt
ranioItaly
PostPosted: Wed Aug 28, 2013 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
hallo matt,
have you checked the 15V at the pin 8 refer to ground and the -15V at the pin 4?
what do you mean with"The signal at the input (pin 6) of the TL072 I read at -6 to -3vpp"?
Have you read it from an oscilloscope ?
The Vpp value is always positive, is the sum of the negative half wave and the positive half wave (i.e. +5V max and -5vmax =10 Vpp)
Bye
