  Muied Lumens Frequencies
Placement of R20 on Digital Klee Board
Page 1 of 1 [3 Posts]
demian
Guest
PostPosted: Wed May 15, 2013 7:04 am    Post subject: Placement of R20 on Digital Klee Board Reply with quote  Mark this post and the followings unread
It seems that on the digital klee board there are 2 different holes you can choose from to put resistor R20 in.
What is the purpose of this and which one should i choose?
 Filesize:  4.92 KB
 Viewed:  4154 Time(s)
sduck
PostPosted: Wed May 15, 2013 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use the hole next to the cap - the other one is a via. I seem to recall there's one or more others like this - pay attention, and if the spacing seems off you might be trying to use a via.
demian
Guest
PostPosted: Thu May 16, 2013 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I just had a closer look to the upside of the pcb and you are right. It's a via, i had soldered in the via accidentally already but i fixed it now.
Cheers!
