Cmd line compile & download works with Arduino 1.5.2 beta
cappy2112
PostPosted: Thu May 30, 2013 8:32 pm    Post subject: Cmd line compile & download works with Arduino 1.5.2 beta Reply with quote  Mark this post and the followings unread
I've confirmed that command line build & download works with
Arduino 1.5.2 and a Due. It will probably work with other models as well.
It was a bit of a surprise though, because the IDE appeared for the duration of the session, then exited. I was just expecting to invoke the compiler & avr dude without seeing the IDE. But, it does work and that make my job a bit easier when I need to update firmware on other system.
(FYI- downloading the hex file to the Due is now down by a different program (called BOSSA), but avr dude is still installed for use with non-Arm based Arduinos.)
1.5.2 is still in beta, and is far (in version number terms) from the current mainline IDE version.
