<on air> Various Artists Live streaming concert in memory of Antimon
portamento question
Page 1 of 1 [10 Posts]
isak
PostPosted: Wed May 22, 2013 11:22 pm    Post subject: portamento question Reply with quote  Mark this post and the followings unread
Hi guys.
i want to build a portamento for one vco but there are 2 types of portamento.
the first type is auto, if i press c1 and release the key and then press c2 it will auto glide.
the second type is... if i press c1 keep on pressing and press c2 only then it will glide.
like in the sh101..
i need the second type, i just dont know how to look it up or how you call it in english Embarassed
any scheme of the second type will be much appreciated.
i thank you in advance,
Isak E.
roglok
PostPosted: Thu May 23, 2013 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
The YuSynth slew limiter is simple enough and should do what you are looking for http://yusynth.net/Modular/EN/DUALSLEW/index.html
isak
PostPosted: Thu May 23, 2013 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
So from what I read it's working only when it gets the gate?
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu May 23, 2013 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes but you want a way of generating a gate only for legato or overlapping notes. What are you using for a keyboard?
isak
PostPosted: Thu May 23, 2013 10:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
you right but if i want to do that i'll just not connect to the gate input.
i'm using midi keyboads with midi to cv.
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Fri May 24, 2013 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
This midi to CV looks like it has exactly what you want.
isak
PostPosted: Fri May 24, 2013 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank for the link.
I'm using this one...
http://www.acxsynth.com/midi2cvlite/midi2cvlitefr.htm
Do you think it will be good?
isak
PostPosted: Fri May 24, 2013 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually I think the chain is midi to cv to yusynth module and from there to the vco.
So what's the deference between the Kenton mid to cv, isnt its the same going on inside the Kenton?
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Sat Jun 22, 2013 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I missed your last post. The Kenton software is written to detect overlapping notes and enable glide only for those.
In the olden days, overlapped notes could be detected using the keyboard resister ladder at both ends (like for duo phonic circuits from Odysey and Cat)
You might be able mod the code on your device to produce a glide control gate when you get a second "note on" before the "note off" of the previous key arrives.
Without this extra gate signal, you are only going to get full time glide or no glide.
isak
PostPosted: Sat Jun 22, 2013 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the input.
I'm way far to modified the code.
I'll give yusynth a try, already etched and built it but didnt tried it yet.
