  Twyndyllyngs Live - Back after two weeks Chez Mosc
Whic 10n capacitor to use for IC decoupling
Page 1 of 1 [3 Posts]
rogerlatur
PostPosted: Thu Jun 27, 2013 2:51 pm    Post subject: Whic 10n capacitor to use for IC decoupling Reply with quote  Mark this post and the followings unread
Please, do you know which sort of 10n capacitors I should use between these 2 for the IC decoupling (opAmps in my case) ? Does it make a difference ?
Thank you !
PostPosted: Thu Jun 27, 2013 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
The one on the left. They're called monolithic caps. I always use them for I.C. decoupling. Greencaps and ceramics are fine as well. The one on the right looks like a metallised polyester, or it could be polystyrene. Either way, save it for somewhere where you need good temperature stability, like the timing cap on a VCO or maybe for a VCF.
rogerlatur
PostPosted: Fri Jun 28, 2013 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I will do so. Thank you very much !
