  electro-music.com June Solstice Concert Various Artists
Change Parameter Pages View via midi?!
Page 1 of 1 [5 Posts]
philpot
PostPosted: Sat Jun 29, 2013 3:13 pm    Post subject: Change Parameter Pages View via midi?! Reply with quote  Mark this post and the followings unread
hi there!
this is my first post cause i really couldn´t find anything about this...
is it generally possible to change the parameters view on my G2X via external or internal controls?
for example:
first 8 steps of a sequencer are shown on parameter page A1 and it changes the view on step 9 to parameter page B1 and shows the steps 9-16 while running?
would be awesome!
thanks in advance!
varice
Audio files: 29
G2 patch files: 53
PostPosted: Sat Jun 29, 2013 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome to the electro-music forum philpot Exclamation
Unfortunately, the Parameter Page selection does not appear to respond to MIDI or other commands.
Too bad there are only 8 assignable knobs instead of 16 on the front panel.
When I only need a visual indication of a long step sequencer position, I just assign some main step positions. For example, I have a 16 step sequencer patch that I have 4 steps assigned; steps 1, 5, 9, and 13. This lets me see the first step position and progress through the sequencer loop, and still allows for 4 more knobs on the page to control other parameters.
varice
philpot
PostPosted: Sat Jun 29, 2013 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your help varice!
too bad it doesn`t work that way.....
so i´ll have to find a workaround with the bcr2000 controlling the sequenzer externally.
exeterdown
PostPosted: Thu Dec 26, 2013 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you can tell us what you're trying to do I'm sure there are more ideas floating around.
philpot
PostPosted: Thu Dec 26, 2013 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
for example:
to toggle the view of sequencer steps 1-8 to steps 9-16 while its running,
means, to automatically change the parameter pages from A to B. on the 9th 16th.
i can automate the variations, but no luck with the parameter pages yet...
