  Jez Adventures in Sound
Simultaneous effects on Andromeda? Reverb + Delay + Chorus?
Page 1 of 1 [3 Posts]
bluecloud
PostPosted: Sat Jul 13, 2013 11:03 pm    Post subject: Simultaneous effects on Andromeda? Reverb + Delay + Chorus?
Subject description: Does Andromeda support custom FX configurations?
On some other synths (ie, Novation Supernova, KS5, Yamaha AN1x etc), you can have reverb + delay + chorus or flanger etc all SIMULTANEOUSLY.
I've tried the effects on the Andromeda and there are a few options but they are all preconfigured routings, ie:
- Reverb
- Ping Pong Delay
- Room Reverb + Delay
- Chorus
etc...
Is there a way to setup your own FX routings/enable simultaneous effects as you choose, in whatever order, vs. using these preset FX setups in the Andromeda's effects menu?
Any advice is appreciated on how to achieve this, thanks!
soundwave106
PostPosted: Mon Jul 15, 2013 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately, not that I'm aware of.
The FX are a "nice bonus" but are a little bit primitive even for a synth of its age (basically Alesis Wedge style algorithms). I often turn them off -- or use the Aux output, which bypasses the FX system altogether (sounds a little "cleaner" to me) -- and use external FX.
Peake
PostPosted: Sun Jul 21, 2013 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
The FX chip cost almost nothing to add but its configurations were already fixed in place. When you bypass it, nothing goes through it at all (it's mixed in alongside the analog signal, so when you bypass it's simply removed).
