Receiving Program edit buffer dumps
Page 1 of 1 [4 Posts]
ludovic
PostPosted: Thu Aug 08, 2013 2:20 am    Post subject: Receiving Program edit buffer dumps
Subject description: F0 00 00 0E 1D 02 10
Hello folks.
When you send a program edit buffer dump request (F0 00
00 0E 1D 03 10 F7) to an Andromeda, you get in return a
program edit buffer dump (F0 00 00 0E 1D 02 10 <2341 bytes>
F7).
What do you have to do to upload that dump to an Andromeda
through MIDI ? Mine seems to completely ignore that sysex. The
LCD doesn't even blink.
Thanks in advance.
Pollux
PostPosted: Thu Aug 08, 2013 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I have yet yet to program some C functions which send and receive programs from the A6 yet, but we can try to figure this out together. There needs to be a matrix transform on the resulting SYSEX Data IIRC from the A6 Sysex Specification.
First please be more specific with exactly how you're sending the Sysex to the A6 to begin with, Razz
ludovic
PostPosted: Fri Aug 09, 2013 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Any help I can get. Smile
You mean a way to extract the 2048 bytes of raw program
data from the 2341 bytes of 7-bits-per-byte data in the
sysex ? This is easily done in Perl with
Code:
$pgm_data = pack('b*', join('', unpack('(b7)*', $sysex_data)))
but that is irrelevant to the problem at hand. You do not need
to know what it inside a sysex to send it back to the A6.
Code:
#!/bin/sh
# Send a program edit buffer dump request to the A6 and save
# the response to pebd.syx.
amidi -S 'F0 00 00 0E 1D 03 10 F7' -r pebd.syx -t 1
# Write the size of pebd.syx to stdout. Should be 2349.
find pebd.syx -printf '%s\n'
Code:
#!/bin/sh
# Send the program edit buffer dump back to the A6.
amidi -s pebd.syx
markus.schloesser
PostPosted: Mon Dec 21, 2020 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
anything ever came out of this?
I'm trying to write an adaptation for the Andromeda for knobcraft, and without being able to send to the edit buffer, I can basically stop right now.
I have a "potential bugs of the A6" list which mentions that this functionality is not supported even though the manual states otherwise
