  Paulo Santos Synth-ing NºX
MFOS - Dual AR
Page 1 of 1 [5 Posts]
isak
PostPosted: Sat Aug 24, 2013 3:42 am    Post subject:  MFOS - Dual AR
Subject description: from the synth diy experiment board
Hi Guys
just finished the dual AR from MFOS synth diy experiment board shceme.
its not verified yet and hope to do it soon.
i did mods for possibility to have fast or slow AR.
i replaced C24 and C26 (4.7uF) to 1uF and 10uF with a switch.
you can see it in the next pic.
i removed the 100k output pots, you can attenuate at the input of the other module you connecting it to.
i built this AR Gen on stripboard when C24 is 4.7uF you can watch the Tube Vid in the next link http://www.youtube.com/watch?v=Ep36ZKTA8jc (move to 3:55)
i'm sorry that the vid is in Hebrew but i dont have any other way to show you how the AR Gen is operating.
if you making this please let me/us know its working ok.
NOTES:
1 - there are 2 jumpers, dont forget them.
2 - all diodes are 1N914 or 1N4148.
3 - it runs on 12V and i think there will be no problem to run it with 15V with no mods.
Isak E.
 Filesize:  39.34 KB
 Viewed:  185 Time(s)
 Filesize:  20.25 KB
 Viewed:  201 Time(s)
 Filename:  MFOS - Dual AR Layout.bmp
 Filesize:  825.05 KB
 Downloaded:  136 Time(s)
feggster
PostPosted: Sat Aug 24, 2013 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
good stuff! which bit crusher design did you use in the vid?
isak
PostPosted: Sat Aug 24, 2013 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there Smile
I used this layout (I modded it a bit, the next pic is updated with the mods I did)
Although it shows 9V it works great with 12V
Isak E.
feggster
PostPosted: Sun Aug 25, 2013 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
ahh ok, I like stripboard! cheers.
so is this a modded version of a bitcrusher from elsewhere?
EDIT: I found it Smile
isak
PostPosted: Sun Aug 25, 2013 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it is Smile
Enjoy.
