  Muied Lumens Frequencies
"circuit diagram" for Nord Modular G2 ?
Page 1 of 1 [11 Posts]
FaschingsPrinz
G2 patch files: 4
PostPosted: Tue Apr 03, 2012 12:45 am    Post subject: "circuit diagram" for Nord Modular G2 ?
Subject description: broken USB-connector ? measuring where / what / how ?
Dear friends,
Now it struck me too!
No USB-connection!
Nord G2 Keyboard 1.62 on a Windows XP SP3 laptop.
I read here in this forum that re-soldering the USB-connector may help. Since I´ve never done a thing like that, I brought the G2 to a colleague of mine who´s capable of doing things like that; But he´s no musician and has never had something to do with synthesizers.
He told me he already measured everything but can´t find any broken connections. He connected the G2 to his computer, but nothing happened too (no query for required drivers etc.).
But to be sure he asked me if I can bring him a circuit diagram so he can dig deeper with his measuring without having to guess so much.
Does anybody possess a circuit diagram of a Nord Modular G2 (keyboard) and would be willing to send it to me ?
THANX a LOT in advance,
Markus
keeping my fingers crossed!
"If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
But if I have an idea, and you have an idea, and we exchange ideas, then we BOTH have TWO ideas."
G.B.SHAW
Roland Kuit
G2 patch files: 127
PostPosted: Tue Apr 03, 2012 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Re-soldering is for a broken USB. Or worn out one. I have to do this shortly. Sometimes it seems if a routine is stuck in the G2. A way is to 'reset' the thing by pressing 10 times on/off. Hope this helps.
FaschingsPrinz
G2 patch files: 4
PostPosted: Tue Apr 03, 2012 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image, might have been reduced in size. Click Image to view fullscreen. .. aah, .. "the IT crowd"-trick ? sun-spots anybody?
No, I haven´t done that yet.
Will try it, but will also try [PERFORMANCE MODE]+ [PATCH LOAD] during startup, which I found here somewhere too.
I saw you had the same problems once upon a time.
How did you solve it ?
Markus
G.B.SHAW
Roland Kuit
G2 patch files: 127
PostPosted: Tue Apr 03, 2012 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I had it 2 times and yes, it solved my problem. Jan Punter tipped this off. Good luck!
Estarriol
PostPosted: Wed Apr 04, 2012 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
As far as I know, there are no circuit schemes of NMG2. Maybe the guy at Encore electronics who made a new expansion board could make one coz' he had no problem examining the original expansion.
Dyuing USB chips is a common problem. What's worse, the corresponding USB chip "ISP1181BDGG" is marked as obsolete at Mouser, so finding one could be a problem.
FaschingsPrinz
G2 patch files: 4
PostPosted: Wed Apr 04, 2012 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a way to find out if it´s my USB-chip that died, or something else ?
How can I separate the possible sources for my broken USB-connection ?
Is there an indicator which will tell me (measuring) that it´s the chip that died ?
G.B.SHAW
voltage control
PostPosted: Thu Apr 05, 2012 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
You can measure for continuity between the 4 connectors in the usb port and points on the circuit board that the corresponding usb port pins lead to. If these connections prove to be in order, and your computer does not "see" the G2, there is a good chance that the usb chip will have to be replaced.
Baby
PostPosted: Thu Apr 05, 2012 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.datasheetcatalog.org/datasheet2/e/0zqflkq25g93q2d9wx1iei08zs3y.pdf
Check for proper voltages on the proper pins. If any are grounded out, it's dead.
http://www.stericsson.com/technical_documents/CD00222753.pdf
Useful info.
http://www.canics.com/searchresult.php?search_db=true&part=ISP1181B&multi-Search=Multi-Search&source=chipcatalog
Supplier(?)
You'll need skillz to replace it...
General Elektrick
PostPosted: Fri Apr 06, 2012 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a lightning strike destroying my USB connection on the G2. I got help for around 250 € here:
http://www.synthesizerservice.de/
For this prize they replaced a led display as well which did not lit up. Pretty fair price. recommended by me...
Greets,
Chris aka general elektrick
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Estarriol
PostPosted: Thu May 03, 2012 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
A circuit diagram for NMG2 is a big thing. It basically requires reverse engineering the hardware, which equals time & skill. I'm currently trying to reverse G2 display board schematics because it has no DSP on board AFAIK. But it still requires bill of materials to be made, all of the electrical connections between components on the board (node list, sometimes called a net list) to be identified and so on.
FaschingsPrinz
G2 patch files: 4
PostPosted: Wed Sep 18, 2013 4:47 am    Post subject: broken USB-connection @G2 = REPAIRED ! Reply with quote  Mark this post and the followings unread
..by the way.
I followed #General Elektrick 's advice and did contact "SynthesizerServiceDepartment".
If you do so, you get an email with an identification-number; pack your synth and write this number on the box and send it there (clever way of handling).
After a week I received a quote, two more weeks later I got my G2 back repaired.
It did cost around 250Euro.
According to SynthesizerServiceDepartment the reason is electrostatic charge when plugging the USB-cable.
The repair he did to the USB-connector did cure this too, so it should never happen again.
I´m HAPPY
G.B.SHAW
