  PHOBoS presents: Smokers Delight (light em up!)
Steiner Synthacon VCF
Page 3 of 4 [80 Posts]
-minus-
PostPosted: Thu Aug 18, 2011 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
well I am now on the 5th board layout and I have had no luck Crying or Very sad . I'm unsure what I am doing wrong here. I have literally copied onto stripboard, the schematic exactly as it is on the CGS site. Are these transistors so hit and miss? Do I need a bunch of them to test and see which combination works best? I'm getting very little sound from the output, and I only get sound if I bypass the 47K resistors on the HP BP LP inputs. I just cant work this out... It IS haunting me now and I can't let it go! I have checked for solder bridges etc. I have reflowed all solder on the reverse of the board. scratch
Last night I had a go at building this on perf. I had the opamp section working fine. Then I built the transistor section to the right of the ladder. I hooked up the ladder and CV section on my breadboard to this and it worked fine. Then I soldered the rest of the circuit and it wouldn't work. Confused
I've ordered some more 2N2222's but they wont be in until next week. If this keeps failing I'll get a couple of boards from Ken and try that. It's not that I don't want to support CGS! I just like the challenge of stripboarding and would like to build my synth that way. I'll continue with this... I cant give up on this now!
-minus-
PostPosted: Sat Aug 27, 2011 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally! After one more go at this, I have a working board! Very Happy
I had to basically cut a piece of stripboard EXACTLY in the pattern of my breadboard: 8 columns side by side of 5 hole strips, 20 strips deep. Then it was just a matter of replicating my working breadboard....
I'm a bit annoyed I couldn't figure out why the other ones wouldn't work, but I do have a working filter so I should be happy.
The sun is rising again and I'm fully tanked up on coffee.... so I might just push my luck and solder another one for good measure!
-minus-
PostPosted: Sun Aug 28, 2011 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just got a second filter working! Very Happy Had a bit of trouble at first. Was not getting any sound in low pass mode.... BUT, I reheated the solder around that area and success!
See, this is all part of the curse... talking to oneself! Laughing You have been warned!
otherunicorn
PostPosted: Sun Aug 28, 2011 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Talking to your self is one thing - expecting an answer is another!
http://www.cgs.synth.net/
Mongo1
PostPosted: Fri Dec 23, 2011 10:16 pm    Post subject:
Subject description: Another one bites the dust
Well, it appears another woolly mammoth has wandered too close to the tar pit.
I'm stuck in Synthacon hell, believing with all my heart that these two miserable little transistors have everything they need to thrive, but no dice.
Symptoms- sorta filtery response on lowpass and highpass, but very low output. Insert a signal into BP, and its about 10 times louder. "Q" pot does absolutely nothing. Op Amp stage seems to function ok. CVs seem to do about what I'd expect.
I've put a 2K trimmer in place of the 2K2. I'm using the 3906 and 3904 transistors in the amplifier, and 2n2222s in the filter core. I've used trannies from these batches in other projects with the no problem, so I don't think it's the reverse pin thing. I did insert the 04 and 06 into the board backwards.
DC voltages look reasonable according to the diagram in this thread, but I'll take another look at that tomorrow.
Here's a couple of weird symptoms:
I put a signal in the LP input, I touch a scope probe to trace that connects the collector of the first tranny to the base of the other. When I do that any sound I have coming out stops, and stays off as long as I have the probe there.
Also - when I first turn the system on, I can hear something that sounds much more 'Q'y and but that fades in to the dull sound I normally have.
I just can't believe that a board this simple is causing me so much grief.
If anyone has any ideas I'd sure appreciate it.
Thanks
Gary
otherunicorn
PostPosted: Fri Dec 23, 2011 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
The "fadey" business suggests an electrolytic is involved. Check that your 0 volt line isn't broken somewhere. I've had similar sorts of things happen in other modules with a broken 0V line.
You may have broken a track or lifted a pad on the PCB. Single sided boards do not like a lot of heat.
Ken
Mongo1
PostPosted: Sat Dec 24, 2011 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - I'll check that....
Gary
Paradigm X
PostPosted: Thu Jan 05, 2012 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you share your layout please minus?
Im a big fan of stripboard, and been meaning to try a layout at this, but quite new at stripboard layouts so always helpful to see others.
Cheers, Ben
roglok
PostPosted: Sun Jan 15, 2012 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally got my Synthacon stripboard working. I had to substitute the 2N2222A/2N2907 with 2N3904/2N3906 to get an active full range on the frequency pot. Filter sounds great!
But... I have one problem:
On the last quarter towards 15V end (filter open), the frequency pot becomes really noisy, as if there's dust on the carbon track. This happens only when actually moving the wiper. I'm using 16mm Alpha pots and have tried several of those with the same result.
Not sure what this issue related to... Are 15V too hot for my pots or is it something else?
otherunicorn
PostPosted: Sun Jan 15, 2012 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've never heard of the frequency pot doing that. The resonance pot is known to do that in the earlier designs.
15V is not too hot for the pot. If you have built it as per the diagram, there is a low pass filter (220k and 1uF) that should prevent any such pot noise from getting through.
roglok
PostPosted: Sun Jan 15, 2012 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
aaah, thanks ken! that was the hint i needed. i accidentially put a 33k instead of a 220k after the cv input. now the noise is gone! i only have to recalibrate the thing. Smile
stefanosdan
PostPosted: Sun Jul 29, 2012 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
haima wrote:
thanks for the reply ken. it seems all that my PCB (version 1.3) of the filter is correct DC wise.. there's just some problem with the AC signal part. pretty sure it's not the trimmer - i tried all positions and even disconnecting it, no change.
i've checked repeatedly for bad solder joints and track lift off problems - couldn't find anything. there MIGHT be something there, but i couldn't find it.
is your pcb version 1.3 new? has anyone else successfully built one? i couldn't see any errors in the layout but i've only traced parts of it while looking for the problem.
i've actually got a problem with my veroboard version too (i seem to be cursed with this filter! Mad ). the filter works perfectly apart from a very loud hum/buzz that seems to be picked up via the LP input. it sounds like a disconnected ground wire kind of buzz, but you can filter the buzz completely away with the frequency cut-off knob all the way down.
> it makes no difference if all the inputs are shorted to ground - still hums just the same.
> all the audio i/o wires are shielded (shield terminated at only one end).
> the entire pcb is enclosed in a grounded aluminium hobby box (i thought it might be EMI)
> it doesn't seem to be a ground loop with other modules - it still hums in complete isolation.
it's driving me a little crazy... anyone got any ideas? anyone had a similar problem with this filter?
I have EXACTLY the same problems... Has a solution been found?
chguigoz
PostPosted: Fri Sep 07, 2012 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
I have the same problem of hum. My eurorack have two power supply, one well filtered and the other not. The hum disapperead when my filter is connected to the good one. Check your power supply and be careful to avoid ground loop, this filter is very sensible.
mubase
PostPosted: Sat Apr 27, 2013 9:05 am    Post subject: Ken stone Steiner VCF fix.
Subject description: Happy to say...
Just had a careful look at this forum post on Ken stone's Steiner VCF. After having one for 2 years now to put inside my WSG Redux I haven't been able to get the resonance control doing anything. It was changing the gain slighty but that is all.
I had another look today following the idea there might be a bad trace on the PCB. There was!
In between the middle resonance pot connection and the 10uF capacitor's - terminal . after having connected the cap's - terminal straight up to the pot connection I got a very lovely resonance. Smile
I am using a 2.2K resistor for the 'q' which barely rings but I might try a lower value for oscillation. absolutely beautiful filter. If I plug 3 of the WSG oscillators into the three different filter inputs (LP,HP,BP) I get some very nice panning effects when the cutoff is VC'd by the LFO...
If you want to see the WSG redux in action theres a short vid here:
http://www.youtube.com/watch?v=z22abVAWuSw
but it was filmed before the Steiner VCF fix..
All the best . Razz
Steve.
There's a crack in everything...Thats how glue manufacturers make a living.
abelovesfun
PostPosted: Wed Sep 18, 2013 3:01 pm    Post subject: I could also use some help Reply with quote  Mark this post and the followings unread
I've got similar issues.
Signal comes through unaffected via HP and less so via BP - no sound from LP input. Filter and Resonance seem to have no effect. Attached are my voltage readings and pictures of the build (I'm still a novice builder).
Any help would be appreciated. Should I swap out the 2n2222s?
Experimental and modular music at: https://soundcloud.com/she-suburban-heroin-electronics
I make Eurorack DIY Kits (pcb and or panels also available): aisynthesis.com
windcriesMarigold
PostPosted: Sun Aug 16, 2015 4:13 pm    Post subject: optimizing the CV range Reply with quote  Mark this post and the followings unread
Hello,
I know that Ken talks a bit about "tweaking values" in the description and I know there is a trimmer included also...but I was hoping someone could talk about tuning the range of this filter a bit. If I select transistors for the most gain, will that give me the most range?
My potentiometer only really starts to pick up at about 50-75% turned - and with the offset voltage turned up, I find that the range is pretty comprised.
wackelpeter
Audio files: 10
PostPosted: Mon Aug 17, 2015 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
do you have an PCB from Ken or anyone else or doing your own or stripboard?
i haven't built this version (okay i did but never finished) but Ken's other version of that filter and Ives' (Yusynth) version too...
the latter both work really fine... they have an trimmer for CV-Rejection included...
http://www.cgs.synth.net/modules/pic/schem_cgs35euro_steiner.gif
don't know how you've trimmed your VCF... i mostly do it by ear or better to say what sounds most satisfiyng to my ears... this is could be of course not the original Sound of the filter but as Long as i'm happy with it, who cares...
roughly i trimm them mostly between two third and the latter quarter of turning the frequency pot the filter is closing fully with 0V CV-Input... and then continue to a Point where i think it's sounding okay...
btw. is this running on 15 or 12V? did you left the 2 diodes out if you're running it on 12V?
another Point to tweak could be reducing the 100k resistors at the CV Inputs/frequency pot a bit...
windcriesMarigold
PostPosted: Mon Aug 17, 2015 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've got it all breadboarded up - so there is plenty of room for experimentation.
i'm not doing much testing with external CV, just working with the steady DC from the cutoff pot. +/-12v, 6-diode version.
have the trimmer on there, but even with it, i'm finding it hard to get an ideal range. one of the big things with this filter is the Q can move to oscillation pretty quickly in the higher frequency range, which i'd like to even out a bit, if possible.
i could probably use lower-value caps for the filter core, also - but i was curious if there is a way to gauge this all with regard to the driving transistors' gains.
windcriesMarigold
PostPosted: Mon Aug 17, 2015 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, i've gone down as low as 500pF for the filters - and it didn't change much. there is still about half of the cutoff pot that is in the "sub-audible range" -
however, i wonder if it's not so much that a low-frequency is being produced, but rather that there is a minimum amount of voltage that needs to be sent, in order to get all of those diodes playing nicely..
windcriesMarigold
PostPosted: Mon Aug 17, 2015 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
a little bit more messing with the cv trimmer and i think it's a pretty good "feel" now..still curious about diodes as VC resistors, if anyone has a suggestion.
also curious, does anyone have any thoughts about adding a notch filter to this design? i wonder if the topology is similar enough to a standard SVF to pull it off..
windcriesMarigold
PostPosted: Mon Aug 24, 2015 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'm still dealing with the cutoff pot range. It seems like the best solution is to just attenuate the CV input and the cutoff pot input to the ideal operational voltage - but I'm not sure why this is necessary.
Are people generally finding a full range of audibility for their cutoff pot at +/- 12v? It seems like if I trim it in one direction, I'm getting too much high frequency and if I trim it in the other direction, I'm getting too much low frequency.. It seems like there's not much "sweet spot."
windcriesMarigold
PostPosted: Mon Aug 24, 2015 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is also a pretty harsh "ON" when the filter clicks into action for the bandpass and high pass.. I imagine this is just a feature of a diode-based filter - but I wanted to see if other people had the same experience.
windcriesMarigold
PostPosted: Sun Sep 06, 2015 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
anyone?
LFLab
PostPosted: Wed Sep 09, 2015 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built a Steiner VCF, but I think I used the schematics and layout of Yves Usson (yusynth). Mine works great, and I often switch filtermode during a patch, no pops or clicks.
Have you tried comparing the schematics?
lysergist
PostPosted: Mon Jul 04, 2016 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Same issue here... My filter worked perfectly on breadboard and then when stripboarded LP and HP doesn't want to work (really low output), but BP works perfectly. I verified 100 times the circuit. There's no error... So i don't know, Minus, mysteries...
(Messy design i know, i had to do with my last stripboard)
 Filesize:  83.97 KB
 Viewed:  128 Time(s)
