  Muied Lumens Frequencies
Ray's Five Octave Switch Layout/PCB?
Page 1 of 1 [6 Posts]
tomas1808
PostPosted: Fri Sep 27, 2013 3:49 pm    Post subject: Ray's Five Octave Switch Layout/PCB? Reply with quote  Mark this post and the followings unread
Has anyone made a layout for the Octave Switch made by Ray?
This is the one:
If not I'll do the layout myself
Mongo1
PostPosted: Sat Sep 28, 2013 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I was just considering doing something like that myself. If you do, let me know - I'd probably buy a couple from you...
Gary
tomas1808
PostPosted: Sat Sep 28, 2013 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did a layout yesterday but I am not too sure how to aproach the 2.5V shunt regulator diode.
What I am supposed to do with the "Adj" pin? Should I leave it 'open'?
Also, are bypass caps placed as they should?
I put the 100K resistors of the exponential convertor there. I think they are not needed.
Someone please check, this is my first layout ever!
Nardu
PostPosted: Sun Sep 29, 2013 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Just see the datasheet for LM336Z-2.5 and LM4040-2.5 ; don't connect the "Adj" pin
You have a little error on PCB - see image
 Filesize:  99.64 KB
 Viewed:  140 Time(s)
http://nardusynth.blogspot.ro/
tomas1808
PostPosted: Sun Sep 29, 2013 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice catch!
I'll leave 'adj' pin disconnected.
I'll try to etch one soon to try it out.
Thanks Nardu.
JanneI
PostPosted: Wed Jul 13, 2016 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
ADJ should be left open. Here's a verified veroboard layout.
