Is there a way to make a SeqNote module polyphonic?
Page 1 of 1 [5 Posts]
ark
G2 patch files: 31
PostPosted: Wed Jan 12, 2011 8:37 am    Post subject: Is there a way to make a SeqNote module polyphonic?
Subject description: There seems to be an anomaly in SeqNote's behavior
I had the probably naive idea that in a polyphonic patch, I might be able to store a different note in each voice of a SeqNote module, so I cobbled up the attached patch to test the hypothesis. The patch is simple, either recording in all voices or playing back in all voices.
What I found was really weird. If I hold down the record button and play a chord, apparently the SeqNote module records only a single note of that chord in all voices. Except that sometimes it records all three notes in a single step, but not in the others.
Am I missing something here? Is there no reliable way to talk a SeqNote into recording a different note in each voice?
SeqNote anomaly.pch2
Hold the first button in panel A1. While doing so, play and hold a 3-note chord. Let it fill the sequencer, then release the button.
I would expect the chord to continue to sound, but what happens on my G2 is that only one note sounds--except sometimes
 Filename:  SeqNote anomaly.pch2
 Filesize:  1.47 KB
 Downloaded:  1169 Time(s)
mush
PostPosted: Wed Jan 12, 2011 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Can't you use voicenumber to route a value for each voice to a separate noteseq? Connect Status - Voice. No to a MUX (control input). Use output from keyboard to input and route the output to rec input on 8 noteseq or less if polyphony is less.
Route the outputs into a mux and control it with the same voice.no.
mush
PostPosted: Wed Jan 12, 2011 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Tried it in your patch:
http://www.kufrec.com/temp/Waste.pch2
ark
G2 patch files: 31
PostPosted: Wed Jan 12, 2011 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm puzzled -- when I try your version, I can hold down the button, then hold a 4-note chord, but what eventually comes out is not the four notes of the chord.
exeterdown
PostPosted: Sat Oct 19, 2013 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I just asked the same sort of thing over here:
http://electro-music.com/forum/post-391758.html#391758
This seems a more appropriate forum.
