What I'm making and ?about power supplies?
Page 2 of 2 [28 Posts]
Goto page: Previous 1, 2
PostPosted: Thu Aug 01, 2013 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
If you don't plan to use it with any external voltage sources, or if you're ok always requiring that the VCA be driven from a higher voltage, that should work. But if you build the voltage division/gain adjustment into the VCA you will be locking yourself out of using other, smaller voltages to drive it. Smile
It's all tradeoffs....
SineHacker
PostPosted: Thu Aug 01, 2013 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
In this case I'm working on a self-contained unit as opposed to a modular one, I will try it the way you suggested though because I definitely want to build something modular next time
aidanrtaylor.co.uk
robynm
PostPosted: Thu Oct 24, 2013 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I just learnt a lot, thanks for having this conversation guys.
I make music
