waveform blending for VCO
Page 1 of 1 [6 Posts]
olledahlberg
PostPosted: Fri Oct 25, 2013 11:56 am    Post subject: waveform blending for VCO Reply with quote  Mark this post and the followings unread
Im building the VCO and Im thinking how to make it like a Moog VCO where it is possible to blend between different waveforms? Is this easy or hard to make? Would it work if I build in a small mixer where all waveforms are connected to it?
Audio files: 131
PostPosted: Fri Oct 25, 2013 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I'm not sure how to sweep between waveforms but building a mixer is pretty easy .
When i first started with diy modular about 8 years ago i was forever needing mixers before my vcf's & vca's , when i re-built my system in 2009/10 i made a mfos simple audio mixer for the filters & vca's.
here's the link to my 12dB sv-vcf with it's 8 channel mixer , handy when wavefolders & wavefreakers & frequency dividers get added to a system Smile
http://electro-music.com/forum/topic-44528.html
epicyclus@skrogmusic.plus.com
Audio files: 131
PostPosted: Fri Oct 25, 2013 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
"made a mfos simple audio mixer for the filters & vca's"
Apart from this vcf which i modded for extra inputs.
Embarassed
Smile
olledahlberg
PostPosted: Fri Oct 25, 2013 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, that sounds good. what pot values are you using for signal input?
cheers
Audio files: 131
PostPosted: Fri Oct 25, 2013 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
100K
ashleym
PostPosted: Fri Oct 25, 2013 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or perhaps you could put two waveshapes into either end of a pot and take the output from the wiper. You will need to use a linear pot. Make sure the levels of each are fairly equal on the way in so you get an equal balance at the centre of the pot's travel. Try a fader style linear pot so you could do some DJ style crossfades. Perhaps a diode on the way in???
Or blend a few more on a joystick. You get a lot less travel on a joystick pot- if you see what I mean- so this might take a bit more experimentation. Or have one axis as waveshape blend and the other axis could be PWM or something similar.
