  Various Artists Live streaming concert in memory of Antimon
Using very thin wire?
Page 1 of 1 [4 Posts]
rogerlatur
PostPosted: Thu May 23, 2013 11:18 am    Post subject: Using very thin wire? Reply with quote  Mark this post and the followings unread
I ordered the wrong wire at mouser and I have a question:
Is there a risk/disadvantage to use 30AWG wire for analog circuitry instead of 22 or 24? I mean is it too thin to wire pots, jacks, bananas... in term of conduction?
Can I wire also to a power supply or is it made to use with digital circuits?
I have no idea if the thickness is important for current transfer for instance.
PostPosted: Thu May 23, 2013 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thickness has SOME importance in conduction of current, I would not use thin wire for power supplies because it could heat up more than it should.
But the main problem I would have using 30ga for panel components is physical strength. I have enough trouble in some projects with resistor leads and such if they're not carefully relieved of strain.
rogerlatur
PostPosted: Mon May 27, 2013 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same opinion here about strength. It is very, very thin. I ordered new wire.
Thank you!
rogerlatur
PostPosted: Sat Oct 26, 2013 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I found this page with AWG table (incl. drop and load realtime calculations) and forgot to post the link here. I thought it might be useful for others too:
http://www.powerstream.com/Wire_Size.htm
