  Antimon Antimon Waves
G2 DSP EXPANSION BOARDS ON SALE AT ENCORE ELECTRONICS
Page 5 of 5 [109 Posts]
Goto page: Previous 1, 2, 3, 4, 5
Audio files: 139
PostPosted: Sun Nov 03, 2013 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Wouter, your signature is very interesting. Your multi-controller software looks quite nice. I have spent a bit of time looking at your other projects. They are splendid.
wave
wouter
PostPosted: Mon Nov 04, 2013 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
Electronic Music - www.insanic4.com | Music Production Resources - www.granucon.com | Netlabel - www.sonicengram.com | Multitouch Controller - www.gesturespark.com
tagirov
PostPosted: Fri Oct 03, 2014 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys
it's my first post here @ electro-music.com, I hope someone's still reading this topic.
I have a G2 Engine and recently bought and installed DSP expansion from Encore Electronics.
Installation was pretty simple, and the Engine is loading and running.
But how do I check that the expansion board has been detected and is in use?
Audio files: 369
PostPosted: Fri Oct 03, 2014 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome tagirov
Hm I don't recall that there is any real indication in the editor, but you can always try to fill up all slots + their fx areas (eight areas total) with e.g. three reverbs in each. If none of the cpu meters go into the red at that point your expansion works. Patch an oscillator through each reverb bank and then into a 2-out module in each slot so you can listen and make really sure.
varice
Audio files: 29
G2 patch files: 53
PostPosted: Sat Oct 04, 2014 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
tagirov wrote:
...But how do I check that the expansion board has been detected and is in use?
Congratulations on getting a G2 Engine along with the Expansion board Exclamation
There are several ways to test that the G2 expansion is active on an Engine. One way is to load a patch into one active Slot and then check how many Voices are available. For example, load the linked patch into a single active Slot, you should see a Voice count of 30 in the Editor:
http://electro-music.com/forum/topic-52152.html
varice
tagirov
PostPosted: Sat Oct 04, 2014 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanx Varice!
I've loaded your patch, it seems that all 30 voices available.
Thanks a lot!
Best regards, Ruslan Tagirov
bananabreadman
PostPosted: Sat Dec 31, 2016 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Encore is shipping more of these right now. Time to jump in I think.
First, bulk purchase anyone? I saw this suggested way back when, and I wonder if anyone tried. If we were collectively to buy 10, for example.
Second, I wonder if anyone can tell me how 'easy' it is to install. I've done a RAM upgrade or two in the past, but that's the extent of my 'circuit bending' skills. Should I plan to have someone install the Expander for me?
Third, Canadian dollar exchange really sucks right now. Sad
G2Psy
PostPosted: Sat Dec 31, 2016 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's dead easy on the Engine. Open cover, push in board, screw in board. Dunno if it is just as easy on the keyboard models.
uyoyu
PostPosted: Mon Mar 13, 2017 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in buying an expansion board, are there any sellers in Europe ?
