Appliancide*
Joined: Jul 04, 2007 Posts: 119 Location: Paul lives in a 1920’s film
Posted: Wed Jan 04, 2012 8:18 pm Post subject:
Yves, would it be ok if I posted I posted information on building your modules for 12V systems over at Muffs? We are trying to put together a one stop resource for converting back and forth between 12V and 15V systems. _________________ http://appliancide/blogspot.com |
yusynth
Posted: Fri Jan 06, 2012 5:16 am Post subject:
Appliancide* wrote: | Yves, would it be ok if I posted I posted information on building your modules for 12V systems over at Muffs? We are trying to put together a one stop resource for converting back and forth between 12V and 15V systems. |
No problem, go ahead. _________________ Yves |
ltm
Joined: Jan 15, 2013 Posts: 6 Location: the netherlands
Posted: Tue Jan 15, 2013 6:46 pm Post subject:
-> yusynth: and and... what about the clock divider?
-> appliancide: do you have a link to this thread? maybe question 1 has already been "answered" there... |
yusynth
Posted: Fri Jan 18, 2013 12:38 pm Post subject:
ltm wrote: | -> yusynth: and and... what about the clock divider?  |
ltm
Posted: Sat Jan 19, 2013 3:31 am Post subject:
yusynth wrote: | ltm wrote: | -> yusynth: and and... what about the clock divider?  |
oops... if it likes 12v without a modification (http://yusynth.net/Modular/EN/DIVIDER/) |
yusynth
Posted: Sat Jan 19, 2013 5:42 am Post subject:
OK I understand now... Yes it should work without modification at 12V. _________________ Yves |
ltm
Posted: Sat Jan 19, 2013 12:50 pm Post subject:
cool/thank you! |
flab
Posted: Mon Feb 11, 2013 8:07 am Post subject:
well hello,
about the VCO(12 volts) as dstrength mentioned above - replacing R3=15K, and R5=130K, and R7=130K make the trick - is there a normal behaviour?
anyone tried it-
thank you in advance people- |
flab
Posted: Tue Feb 12, 2013 3:21 pm Post subject:
looks like it is tricky enough=
so the best choice is to run in a way that is designed to run -
15v it is |
robboten
Joined: Nov 26, 2009 Posts: 36 Location: stockholm, sweden
Posted: Thu Aug 08, 2013 11:59 pm Post subject:
I also work with 12V in my modular. Am going to build the EMS filter and am wondering if I can just skip the regulator? And if so, which other components nearby I should change/remove? Also, how would -9V be generated from -12V?
NVM - found the answer in this thread - http://electro-music.com/forum/topic-24482-50.html |
littlem4tt
Posted: Wed Aug 28, 2013 8:26 pm Post subject:
I had great fun building the wavefolder for eurorack. This was my first yusynth and pcb etch. I decided to add pads for the pots before I made the press and peel so I could then add short wires to the pcb. This way I could mount the pots straight onto the front panel.
I am very impressed with the sound of this module. It works great with synths and is fantastic on drums. I look forward to making many more yusynth modules!!!
Description: |
Filesize: |
41.92 KB |
Viewed: |
18326 Time(s) |
Description: |
Filesize: |
129.63 KB |
Viewed: |
251 Time(s) |
Description: |
Filesize: |
115.6 KB |
Viewed: |
271 Time(s) |
littlem4tt
littlem4tt
LektroiD
Joined: Aug 23, 2008 Posts: 1009 Location: Scottish Borders
Posted: Tue Oct 15, 2013 12:18 am Post subject:
Without any intent of hijacking this thread (although it is Euro/Yusynth related). I was wondering if anyone knows where I can get Euro panels for Yusynth circuits. _________________ LektroiD |
littlem4tt
yusynth
Posted: Fri Nov 01, 2013 1:18 pm Post subject:
Today I posted on my site a new version of PCB for the Steiner VCF providing pads for a Eurorack PSU connector _________________ Yves |
littlem4tt
Posted: Sat Nov 02, 2013 12:25 pm Post subject:
you steal all my ideas  |
littlem4tt
Posted: Wed Dec 11, 2013 11:11 pm Post subject:
Your a genius dstrengh! I wanted to put my cv standard module in the 12volt rack and your resistor calculations worked perfectly. Thank you very much. |
littlem4tt
chrisp
Joined: Jan 14, 2010 Posts: 6 Location: Athens,Greece
Posted: Sun Feb 23, 2014 11:08 am Post subject:
i have a question about ARP 4072.
it's need some components changes to run perfectly on +\-12 as the Moog filter? |
littlem4tt
littlem4tt
diablojoy
Joined: Sep 07, 2008 Posts: 805 Location: melbourne australia
Posted: Thu Mar 06, 2014 6:50 pm Post subject:
hmm is there interest in a 4HP version of the yves's simple VCA single cv input, signal input and only the 1 output , but there are connectors for the others if you want , i should get back a prototype in a couple of weeks.
this is the 2SC1583 version
did this one for myself and putting 4 behind a 16 hp panel _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any Last edited by diablojoy on Mon Apr 07, 2014 1:19 am; edited 1 time in total |
01012k7
diablojoy
Posted: Mon Apr 07, 2014 1:10 am Post subject:
VCA prototype seems to work as expected
still some testing to go to make absolutely certain
some crappy pics of quad version in 16HP
really like this VCA - simple and efficient, i plan on having 30 or so eventually
Description: |
Filesize: |
392.39 KB |
Viewed: |
207 Time(s) |
Description: |
Filesize: |
643.68 KB |
Viewed: |
234 Time(s) |
Description: |
Filesize: |
445.15 KB |
Viewed: |
237 Time(s) |
as good an answer as any |
