New Arduino-based eurorack module in preorder
Page 1 of 1 [5 Posts]
scottwilson
PostPosted: Mon Dec 30, 2013 7:21 pm    Post subject: New Arduino-based eurorack module in preorder Reply with quote  Mark this post and the followings unread
Not sure if there's anyone on here who's _not_ on muffwiggler, but in case, I wanted to announce that I'm taking pre-orders for my new module until the end of January. In order to help raise money for the initial production run of panels and PCBs.
Full details and ordering information can be found at the links below, but I've included a little bit of information and a couple of videos as well.
http://nw2s.net/about/
http://nw2s.net/order/
https://www.youtube.com/watch?v=BJSbaqXBrfA
https://soundcloud.com/scottwilson/nw2s-b-demo3-looped-sample
https://soundcloud.com/scottwilson/nw2s-b-output-prototype-demo-2
The nw2s::b is an open, Arduino-based modular synthesis development platform for the Eurorack format with 55 independent interface points including CV and digital input and output jacks, knobs, buttons, and even audio. Yes, this module will allow you to emulate almost any existing sequencer, LFO, envelope generator, arpeggiator, quantizer, control voltage processor, hybrid oscillator, or other insane source of uncertainty.
More importantly, it will allow you to build nearly anything you can imagine.
The platform itself is a combination of hardware and software. The software provides a framework which allows you to configure the behavior of the module in a declarative syntax that should be relatively easy to pick up even for those with minimal programming experience.
The framework can easily be extended to provide a consistent development experience or it may be bypassed completely for access to the raw hardware.
Expansion possibilities are provided through the standard Arduino expansion ports which have been exposed via pin headers including I2C, SPI, GPIO, USB, and UART. Additionally, serial communication with a host can be established over Bluetooth.
Regards,
Scott
Audio files: 214
G2 patch files: 319
PostPosted: Mon Dec 30, 2013 8:19 pm    Post subject: Re: New Arduino-based eurorack module in preorder Reply with quote  Mark this post and the followings unread
Oh that would be me Laughing
Interesting project, thanks for posting it here too!
EdisonRex
Audio files: 171
PostPosted: Fri Jan 03, 2014 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Me, too, I browse Muff Wiggler but I have too many places to go as it is.
Thanks for posting this, it's very interesting indeed.
Garret: It's so retro.
scottwilson
PostPosted: Mon Jan 06, 2014 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a quick monday update...
Preorders will be open until January 31! http://nw2s.net/order/
Here's a new demo of an emulation of a Turing Machine I've put together to show something using a few more outputs all at once, perhaps with a little context around something you're more familiar with.
http://nw2s.net/a-turing-machine-adaptation/
Regards,
Scott
scottwilson
PostPosted: Tue Jan 21, 2014 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I know you've all been secretly wanting to build you own voltage-controlled wavetable synth, so I write a tutorial to get you started. Complete with Atart 2600 explosion sounds.
http://nw2s.net/a-generalized-oscillator-framework/
(And only a couple more weeks of pre-order - help a guy get this thing funded!)
-s
