ARP 4072 Filter Capacitors
Page 1 of 1 [3 Posts]
marfoski
PostPosted: Tue Jan 14, 2014 5:15 am    Post subject: ARP 4072 Filter Capacitors Reply with quote  Mark this post and the followings unread
I've just built this wonderful filter and, after a good calibration, it's a joy to play it (I disconnected R43 BTW). What concern me is that it sounds so good even if I used dirty cheap ceramic 470pF capacitors in the filter cells, as they were the only of that value in my parts bin, and I didn't even bothered to match them. Now the question is : it's worth changing them with, say, WIMA or polystyrene 1% caps (and what I should expect in terms of quality) or should I follow the golden rule "if it's not broke don't fix it" ?
yusynth
PostPosted: Fri Jan 17, 2014 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably you got a batch of capacitors that were already pretty matched.
If you are satisfied with the sound of your filter then don't try to improve it.
In French we say "Le mieux est l'ennemie du bien" which can be translated as "Better is the foe of Good"
Yves
marfoski
PostPosted: Fri Jan 17, 2014 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
As a matter of fact, all the caps were from the same batch. I have been lucky.
Thank you again, Yves, even for your words of wisdom. Wink
