G2X: replacing the keybed
Page 1 of 1 [9 Posts]
klangumsetzer
Audio files: 15
PostPosted: Wed Jan 29, 2014 5:43 am    Post subject: G2X: replacing the keybed Reply with quote  Mark this post and the followings unread
Hej,
The keybed in my G2X is so worn out that it has become very difficult to play dynamically.
Is there anybody who has replaced the keybed in a G2X?
Which keybeds are compatible?
Is there a technical manual available?
Thanks in advance for helping me out.
best regards
eike
make a joyful noise!
https://archive.org/details/EdP024_Antimon_klangumsetzer_rinden_bark
Electromagnetic Wave
G2 patch files: 34
PostPosted: Wed Jan 29, 2014 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
All keys ? 1 octave ?
This is not for the G2 but this info can help you :
The full velocity issue is dirt -- this is located BENEATH the rubber contact strip and will not be cured without removing that strip and cleaning underneath there.
You could also contact keyboard repair shops; they can likely sell you single plastic keys to replace broken ones on your Stage.
source : http://www.norduserforum.com/nord-stage-forum-f3/replacing-broken-keys-on-nord-stage-1-76-t3369.html
New NS2 with keybed velocity problem from factory (fixed)
http://www.norduserforum.com/post16388.html#p16388
Nord Stage EX SW73 Compact Velocity Repair.pdf
http://www.norduserforum.com/nord-stage-forum-f3/help-key-stuck-at-full-velocity-on-stage-ex73-t3617.html#p22246
http://www.norduserforum.com/nord-stage-forum-f3/how-to-romove-keys-t2770.html
http://www.norduserforum.com/nord-electro-forum-f9/key-repair-of-electro-3-t5782.html
I think the best is to contact keyboard repair shops...
klangumsetzer
Audio files: 15
PostPosted: Thu Jan 30, 2014 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hej electromagnetic wave,
Thanks so much for taking the time to reply and supply helpful links and even cleaning instruction for the stage in pdf format! Very Happy
It is the entire keyboard of the G2X which feels mushy (probably the springs?) and has a more or less digital velocity response (on/off).
From looking at the procedure for cleaning the contacts of the stage it is probably easiest/most time efficient to replace the entire keyboard.
It would be nice to get a weighted one but those selling Fatar keyboard replacements do not seem to offer weighted keboards with aftertouch.
Question
Is there a recommended repair shop in Sweden which could do this?
Is there any sense in contacting Nord keyboards for help?
best regards
eike
dorremifasol
G2 patch files: 49
PostPosted: Thu Jan 30, 2014 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I replaced the keyboard of my G2 some years ago, for its semi-weighted variant. But I found it too bouncy and I reverted to the original keyboard later.
I think the G2X keyboard is exactly the same (TP/9S) but with more keys. I guess you can buy the entire keyboard from Doepfer or any of their distributors. That's what I did.
More details here:
http://electro-music.com/forum/viewtopic.php?&t=28040
Albert
klangumsetzer
Audio files: 15
PostPosted: Sat Feb 01, 2014 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hej Albert,
Thanks for the link. Doepfer no longer offers the weighted version with aftertouch: maybe other buyers had similar experiences to yours, who knows.
When you replaced the keybed in your G2 were there any tricks/things to look out for? If you can remember that would be helpful.
I once read that the G2X supposedly used a keybed of better quality so I am unsure if it really is the Fatar TP/9S.
If I got to choose I would opt for the Fatar TP/8SK which my virus kb uses and which feels much nicer. But I guess they are not compatible with each other.
best regards
eike
dorremifasol
G2 patch files: 49
PostPosted: Sat Feb 01, 2014 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember having to do any tricks, the new keyboard was just straight compatible.
I'm afraid I also don't know much about the G2X, except that I wanted one! Perhaps other users can help.
At one point I even fantasized about putting the G2 panel and board into a newly designed wood / metal case with a proper keyboard!
Albert
G2 patch files: 34
PostPosted: Sat Feb 01, 2014 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Or you can clean this one ?? :
http://www.ebay.com/itm/Fatar-Studiologic-Rubber-Contact-Strips-13-13-Replacement-contact-keyboard-strip-/331044738337?pt=US_Pro_Audio_Parts_Accessories&hash=item4d13cdd521
http://www.norduserforum.com/nord-electro-forum-f9/electro-2-touch-sensitivity-vanished-t819.html
vcs_3
PostPosted: Sat Feb 01, 2014 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
clean the rubber contacts with alcohol.
klangumsetzer
Audio files: 15
PostPosted: Sat Feb 01, 2014 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Electromagnetic Wave and vcs_3 for your help.
My G2X which I bought from a gigging musician probably had already seen a lot of live use. It is not only the lacking velocity response but I also think that the resistance (of the springs?) is too soft.
Nonetheless I will check the rubber contact strip when I take out the keybed.
Thanks again for your support!
best regards
eike
