  Les Hall The Les Hall Show
VCLFO2 Problem
Page 1 of 1 [2 Posts]
Audioscape
PostPosted: Tue Feb 11, 2014 11:55 am    Post subject: VCLFO2 Problem
Subject description: LFO Signal Amplitude reduced by low frequency
Hi!
I have a Problem with the VCLFO2:
Everything works fine but when i turn down the frequency to the lowest range the amplitude of the LFO Signal reduces itself to zero.
If this is the case, the signal just makes a little Peak instead of a sine curve.
would be great if someone could help me.
thanks.
M.
yusynth
PostPosted: Tue Oct 14, 2014 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Check that you wired correctly the switch (DPDT type) and also soldered the big capacitor to right place on the PCB.
Yves
