Problem with the Steiner Parker Filter
Page 1 of 1 [2 Posts]
Audioscape
PostPosted: Tue Feb 11, 2014 11:37 am    Post subject: Problem with the Steiner Parker Filter
Subject description: Self oscillation Problem
Hi!
I have the following Problem:
-The Resonance is set on self oscillation. (No Input Signal)
When i set the Frequency now under 150-160 Hz the Signal breaks down.
no Level.
I used this shematic.
http://www.yusynth.net/Modular/index_en.html
Someone has an idea?
Best regards!
M.
Sebo
PostPosted: Tue Feb 11, 2014 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's normal, not all VCFs oscillates in the full frequency range.
I built the Steiner-ParkerVCF, the MiniMoog VCF, the ARP 4072 VCF, the VCS3 VCF, the WASP VCF, the Polivoks VCF, the Sytem 100m VCF, and the MS-20 VCF. The ones that self oscilate in the full frequency range are the ARP 4072, the Sytem 100m and the MS-20. The rest only oscillates for a limited range.
Sebo
My Music:
www.cosaquitosenglobo.com.ar
