Set controls in your patch using javascript
Page 1 of 1 [8 Posts]
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Sat Feb 15, 2014 9:20 pm    Post subject: Set controls in your patch using javascript
Subject description: Another function for the online app.
Another part of the "Multi-file to pch2 patch file utility" has been published.
You can now use javascript to set control values in your patch.
Open your textpad in the G2 editor and type (or paste) some javascript code, the code needs to start with //yo to be accepted.
I have attached an example to get you started. If you 'choose' this file, the system will prompt if you want the code executed. If you click ok, the code is executed against the pch2 object and a link is presented to the new pch2.
The sample shows how to set 4 sequencers to 2 cycles of a sine wave.
I don't know how useful this is going to be to non-javascript programmers.
SelfDemo.pch2
Demo of self setting part of new online utility.
 Filename:  SelfDemo.pch2
 Filesize:  2.43 KB
 Downloaded:  1035 Time(s)
Audio files: 369
PostPosted: Sun Feb 16, 2014 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Not sure I understand this but it sounds awesome! Will try it out when I get the time for sure!
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Mon Feb 17, 2014 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a little difficult to explain in the limited space here so I have started a docs section for the utility. The file types list will get hyperlinks as I get around to documenting them.
Here is a direct link to the provisional documentation.
I should look at adding a snippets section for people to share useful bits of code.
Electromagnetic Wave
G2 patch files: 30
PostPosted: Mon Feb 17, 2014 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
It's the ultimate "patch adjuster" tool!
xav
G2 patch files: 7
PostPosted: Tue Feb 18, 2014 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wish I could understand... that seems amazing!
W.T.
G2 patch files: 11
PostPosted: Tue Jan 06, 2015 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing! Let us pray
Clavia stuff that I use : expanded Nord rack & NM G2 engine.
BobTheDog
PostPosted: Sun Jan 25, 2015 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Very clever as usual!
Works fine for me here in chrome, in Safari though it balks when trying to download the file:
 Filesize:  40.53 KB
 Viewed:  127 Time(s)
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Sun Jan 25, 2015 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bob
Safari haven't made a PC browser for quite some time so it has fallen off my list of things to check.
Seems synthesizing a file download object using an array buffer is a known problem for Safari and there might be a work around I can try.
It doesn't work on IE, even IE11 for some reason as well. They are doing some major revamp of their browsers this year. Fingers crossed they will just start using webkit. Laughing
