 Forum index » Artists » HrastProgrammer
Diodow 32/64-bit VST Synthesizer
Post new topic   Reply to topic Moderators: HrastProgrammer
Page 1 of 1 [4 Posts]
HrastProgrammer
Audio files: 79
PostPosted: Wed Sep 18, 2013 12:32 am    Post subject: Diodow 32/64-bit VST Synthesizer Reply with quote  Mark this post and the followings unread
Both 32-bit and 64-bit versions of my Diodow synthesizer are available for download now ...
http://www.hrastprogrammer.com/hrastwerk/diodow.htm
http://hrastprogrammer.bandcamp.com/
Last edited by HrastProgrammer on Tue Mar 04, 2014 6:12 am; edited 1 time in total
adnauseam
PostPosted: Wed Sep 18, 2013 7:13 am    Post subject: A big thanks to you! Reply with quote  Mark this post and the followings unread
Thanks, Hrastprogrammer
Your earlier posts with sound samples made me curious. Thank you for making it available to download.
Looking forward to trying it out a little later this month.
-adnauseam
HrastProgrammer
Audio files: 79
PostPosted: Tue Mar 04, 2014 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The free Diodow synthesizer has been greatly enhanced with oversampling and sample engine. Sample oscillators are sub-modules inside main oscillators - they share common pitch/frequency parameters together with the same outputs, so they can be used in tandem with the regular oscillators, processed through Diodow engine, etc.
Diodow sample engine supports linear interpolation only and doesn't have high-quality interpolation available in Tranzistow.
The engine can load 8/16/24/32-bit PCM and 32-bit FP mono/stereo WAV files. To load a sample click on the oscillator section name (Osc #1, Osc #2, Osc #3, Osc #4). In case of stereo samples - if you load a sample into oscillators 1 & 3 then left left channel will be loaded, otherwise right channel will be loaded. To remove the sample press and hold Ctrl key and click on the appropriate oscillator section name. The oscillator section name will have an asterisk on front of it if a sample has been loaded into the connected sample oscillator.
Furthermore, some bugs have been fixed and some features polished.
Download here:
The synthesizer is fully functional and there are no disabled features ... use freely.
HrastProgrammer
Audio files: 79
PostPosted: Mon Mar 10, 2014 2:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Diodow announcement with a short review + video on Bedroom Producers Blog:
http://bedroomproducersblog.com/2014/03/07/diodow-hrastwerk/
