Favorite item for weighing down keys?
Page 1 of 1 [19 Posts]
adnauseam
PostPosted: Mon Mar 03, 2014 1:19 pm    Post subject: Favorite item for weighing down keys? Reply with quote  Mark this post and the followings unread
So I've been finding that on occasion I'd rather have a key held down as opposed to other options on my Evolver. It seems like it could be more convenient. I really love my Evolver but some of the parameters really aren't quick to set.
What are your favorite items for holding down keys?
I haven't tried many items yet and what I do have isn't heavy or sticky enough to stay down on the slope of a held key.
Audio files: 213
G2 patch files: 319
PostPosted: Mon Mar 03, 2014 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
tape .. or some cardboard between keys. Or isn't this about keyboard keys?
Audio files: 337
PostPosted: Mon Mar 03, 2014 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could also make a simple foot switch by opening or closing the sustain pedal loop input, if there is one. Not sure which Evolver you have, but from memory i seem to be telling myself it is the Mono...?
Muied Lumens Base Star
Danno Gee Ray
PostPosted: Mon Mar 03, 2014 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've seen matchbooks and folded cash used.
I also saw Keith Emerson use knives...
Piece of toothpick might also work/
Dan
adnauseam
PostPosted: Mon Mar 03, 2014 9:11 pm    Post subject: Ideas.. Reply with quote  Mark this post and the followings unread
Blue_Hell: I'm talking keyboard keys!
I always imagined something just sitting on the key and hadn't considered more of a wedge approach. I'll give this a try.
Muied Lumens I will try a foot switch approach later. No foot switch gear nearby and limited knowledge of electronics. I would find CV switches for controlling many aspects of the Evolver.
Matchbooks sound like a great idea or maybe just folded piece of cardboard. Got lots of that in the recycling bin!
Thanks for the ideas.
Audio files: 370
PostPosted: Tue Mar 04, 2014 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Doesn't it work to just open up the VCA?
Designator
PostPosted: Tue Mar 04, 2014 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.synthtopia.com/content/2009/01/20/ambient-sequencer-as-606-designed-specifically-for-ambient-drone-music/
 Filesize:  32.01 KB
 Viewed:  7416 Time(s)
varice
Audio files: 29
G2 patch files: 53
PostPosted: Tue Mar 04, 2014 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I use a "D" cell 1.5V battery to hold a white key down. Smile
varice
Oskar
PostPosted: Tue Mar 04, 2014 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Back in the day I used to ram my house key so as to keep the lowest F key on my organ for an extended intro to a son we used to do. I think Jimmy Smith used a broken match.
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
adnauseam
PostPosted: Tue Mar 04, 2014 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Antimon:
I suppose opening the amp env is just as fast as wedging it .. Hrm.
Opening the amp wouldn't work in cases where the gate is needed with the arpeggiator or sequencer for example, as opening the amp env doesn't open gate the keys
Audio files: 370
PostPosted: Wed Mar 05, 2014 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
adnauseam wrote:
@Antimon:
Ah of course the sequencer, didn't think of that.
PostPosted: Thu Mar 06, 2014 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I use small electronics screwdrivers like these:
My Korg X3 allows my to select the pedal polarity in the Global settings, so I can easily change my sustain pedal into a release pedal. Then every key I press remains on until I press the pedal.
WARNING: Don't use anything too small. I tried a toothpick once and it slipped out and fell between the keys.
Audio files: 337
PostPosted: Thu Mar 06, 2014 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
This is similar to what I meant, except you make a special pedal. Take a latching foot switch, SPST - solder it to a jack, put it in a suitable box and you have a foot pedal that will let you drone away.
I have made one with two of them in, and I use it for my two keyboards, a Nord Lead and an MPK49, controlling my Evolver.
You could of course use a momentary one and it will be a normal sustain switch, then use Cyno's trick by switching the default polarity as well, or you could go advanced and have one latching switch control the polarity of another, momentary switch and you have both options in a dual pedal.
Audio files: 337
PostPosted: Thu Mar 06, 2014 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm i thought I posted a pic of it before but I can't find it so here it is:
Dual latching foot switch.
 Filesize:  691.04 KB
 Viewed:  133 Time(s)
pyrosonic
PostPosted: Fri Mar 07, 2014 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
For white keys I would use a wooden match under the lip on the front of the two adjacent keys and over the key that you want to hold.For black keys I would wedge a matchbook in between it and the adjacent key.
http://soundcloud.com/pyrosonic-1
https://www.facebook.com/pages/Pyrosonic/106761076017889
http://www.youtube.com/user/pyrosonic
https://www.facebook.com/pages/Whorlweaver/133469163426410
Audio files: 27
PostPosted: Fri Mar 14, 2014 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought Emerson used Nazi Youth knives for this? Smile
audiodef
Audio files: 42
PostPosted: Sun Apr 20, 2014 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a little cup full of those photo frame clips that I use when playing my Programmed Hell series. Hold a key down and wedge one gently in between the held key and the underside of an adjacent key. Can post a photo of this if you're not a picture in your head.
Audiodef
Gentoo Studio
glow worm
PostPosted: Mon Apr 21, 2014 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Right size, right weight and helps keep the creative juices flowing Very Happy
 Filesize:  405.48 KB
 Viewed:  131 Time(s)
It may stop, but it never ends.
A E J O T Z
Audio files: 148
PostPosted: Sat Jul 05, 2014 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
My cats.
They can be quite creative sometimes.
AEJOTZ is pronounced "A-Jotz"
retro-futurism now
electronics = magic
free albums at http://aejotz.bandcamp.com
listen to genre-defying synthetic music at http://sat-5.com
