EFM Wildcat - slide + Glide in 1 stripboard
Page 1 of 1 [3 Posts]
isak
PostPosted: Tue Apr 29, 2014 9:07 am    Post subject:  EFM Wildcat - slide + Glide in 1 stripboard Reply with quote  Mark this post and the followings unread
hi guys,
THIS IS VERIFIED!
i did a stripboard layout of the EFM Wildcat glide/slide and its working great.
one advice is to put one dual gang pot and not two pots.
as well as a switch, i put dual on/on toggle switch to choose between the cv input and the glide/slide output.
works great.
enjoy this small stripboard.
the scheme is attached below on PDF
Isak E.
 Filesize:  55.94 KB
 Viewed:  328 Time(s)
wildcat_001.pdf
 Filename:  wildcat_001.pdf
 Filesize:  3.73 MB
 Downloaded:  282 Time(s)
LFLab
PostPosted: Thu May 01, 2014 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, gated slew sounds like fun, pretty simple too, definitely going to try this!
isak
PostPosted: Thu May 01, 2014 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
Please note that it's working exactly like the SH101 portamento but only with cv/gate keyboards, when I tried using midi to cv - midi keyboards the Slide output (the one that suppose to work only when gated) does not work as it should.
It works but not like the SH101 portamento (which actually was my goal).
I opened a post about this issue, you can see in the next link:
http://electro-music.com/forum/topic-60295.html
Isak E.
