NR2X - what does "PEr" mean?
Page 1 of 1 [5 Posts]
Bacizone
PostPosted: Fri May 16, 2014 3:47 am    Post subject: NR2X - what does "PEr" mean? Reply with quote  Mark this post and the followings unread
I have a Nord Rack 2x, I am using it in Performance mode with Cubase via the E-MU X1 USB MIDI interface.
I set Cubase to 100 bpm, started recording and press Shift+Dump One to dump the sysex of current Performance into a MIDI file.
The dumped Performance seems to be ok, I also checked the Sysex code, it contains all four programs plus the additional Performance details.
When I play it back, (just the dump, nothing else) at 100 bpm, I get a message on the display "PEr" which resembles me to an...Error?
What is this "PEr"? I did not find anything about it in the manual.
If it is an error, how to get rid of this?
thanks!
Audio files: 353
PostPosted: Fri May 16, 2014 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know what PEr means, but just guessing here... Are you sending MIDI clock to the Nord at the same time as the sysex? This could be the problem - try sending only the sysex data by itself and see if that works.
Muied Lumens Base Star
Audio files: 218
G2 patch files: 319
PostPosted: Fri May 16, 2014 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Guessing too .. write protect is on?
Bacizone
PostPosted: Sat May 17, 2014 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
HI,
thanks for the suggestions.
I've just checked, Sync > MIDI Clock is disabled in my Cubase at all MIDI ports, I am not using it these days anyway.
Write protection - maybe this was an issue with NL2 PCMCIA card, but the 2X series has only built-in memory which can not be protected against writing.
I did not get answer from Clavia support.
UPDATE: you can read the solution here, thanks for Nordlicht:
http://www.norduserforum.com/post43900.html#p43900
Audio files: 218
G2 patch files: 319
PostPosted: Sat May 17, 2014 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
:-) end good all good
