N bits Up/Down/Both synchronous binary flip flop counter
Page 1 of 1 [6 Posts]
bantri
G2 patch files: 32
PostPosted: Sun May 15, 2005 1:17 pm    Post subject: N bits Up/Down/Both synchronous binary flip flop counter Reply with quote  Mark this post and the followings unread
An attempt to supersede the default binary couter module adding an up/down input and the possibility to expand no N bits in modular demo...
NBitCounter2005-Bantri.pch2
 Filename:  NBitCounter2005-Bantri.pch2
 Filesize:  2.8 KB
 Downloaded:  842 Time(s)
bantri
G2 patch files: 32
PostPosted: Sun May 15, 2005 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bantri. Great to have you here.
You are a man after my own heart. I love back and forth sequencers, but they are rare. You have done a great job here and this is a great service to me. Do you think you could expand this to include a preset? I would imagine a momentary switch or input signal would asynchronously load the counter you've built.
I've repeated requested that Clavia supple a binary up/down counter with asynchronous preset (or sometimes called load).
Another thing we need in circuits like this is a skip feature.
bantri
G2 patch files: 32
PostPosted: Sun May 15, 2005 1:26 pm    Post subject: diagrams Reply with quote  Mark this post and the followings unread
Thanks
I have to admit that i thought that those digital circuits classes would´nt be useful until i´ve noticed the flipflops in modular.
Here are the links that inspired me to build this structure.
http://www.allaboutcircuits.com/vol_4/chpt_11/3.html
http://www.play-hookey.com/digital/converting_ff_inputs.html
Basically it is a finite state machine where the combinatorial stage has the functions of increment decrement the current state or reset to zero.
It passed my mind to make the function to program an initial state and the other function to skip n states seems a good idea that i haven´t imagined, BUT
flip flops are capable of remembering only 2 states hence the circuit quickly becomes imensely cluttered so i am already thinking to use the clocked sample and hold module as the memory for storing the state because it´s the analog of using 8 flipflops in the finite state machine, so probably i won´t invest more time in binary machines after this one.
The main objective for this is to create a sucession of states in the range of 0 to N-1 to ouput to a second stage that associates those N events to notes in a scale for generating complex live arpegios.
The original motivation for this was first the subarppegio function available only in the nord lead and also by hearing the arpeggios from sources like Rio album from Duran Duran and some Goa from Shakta and Moonweed as an example... which were programmed by hand, but the real fun is to develop some mathematical pattern to occasionally and ramdomly change some notes to avoid repetitive behavior... [/img]
bantri
G2 patch files: 32
PostPosted: Sun May 15, 2005 1:36 pm    Post subject: using SH module for storing integer states Reply with quote  Mark this post and the followings unread
Here is the option i mentioned using the sample and hold module instead of flip flops (thus allowing a less cluttered structure), it consists of a finite state machine that has an initial load value, upper and lower bound detection every time the state gets out of bounds it triggers one of four increment/decrement values.
Probably the next step on the research will be using the sequencer value module instead of the SH module to store 16 individual states.
I currently don´t know if it´s possible but it will be something like setting each of the inputs with a sequence like
1,5,2,3,7,4,8,-1(<EndOfCycle),x,x,x,x,x,x,x,x(<DontCare)
allowing to set individually the next jump for every state thus allowing the most flexible state machine as possible and later cascading/summing two of those circuits, so after the secondary completes one complete cycle it advances the primary to the next state, then your going to hear some really nice trance inducing patterns.
Fstates2005Bantri.pch2
 Filename:  Fstates2005Bantri.pch2
 Filesize:  1.97 KB
 Downloaded:  815 Time(s)
 Filesize:  1.97 KB
 Downloaded:  807 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Sun May 15, 2005 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I made a stupid remark somewhere and things got messed up a bit as a result, sorry.
I locked the original threads, didn't know what else to do.
http://electro-music.com/forum/topic-6407.html&highlight=
and
http://electro-music.com/forum/topic-6414.html&highlight=
Jan.
Rob
G2 patch files: 109
PostPosted: Sun May 15, 2005 3:00 pm    Post subject: Re: N bits Up/Down/Both synchronous binary flip flop counter Reply with quote  Mark this post and the followings unread
There is an other example of an up/down counter with variable direction and step at http://electro-music.com/forum/topic-3035.html.
Redid it for V1.32, the patch found in the above link suffered from a little bug that was fixed in V1.30 and later. It now also has a synchronous reset and a preset value for on a reset.
stepper V1.32.pch2
Forwards/backwards sequencer with variable step and direction, synchronous reset and variable start position on a reset.
 Filename:  stepper V1.32.pch2
 Filesize:  2.72 KB
 Downloaded:  1059 Time(s)
