 Forum index » Instruments and Equipment » Strings and things
BOSS GP10 - Actually pretty good!
Post new topic   Reply to topic Moderators: BobTheDog
Page 1 of 1 [10 Posts]
BobTheDog
Audio files: 32
PostPosted: Tue Aug 12, 2014 3:11 am    Post subject: BOSS GP10 - Actually pretty good! Reply with quote  Mark this post and the followings unread
Hi Guys,
I know a few of you are 13 pin users so I thought I would write a few words about the GP10: http://www.roland.co.uk/blog/new-boss-gp-10-guitar-processor
I didn't have much hope for this and purchased it really to get 6 channel audio into the computer as my StringPort never works and my RMC breakout box has pretty low output.
The 6 channel audio works very well over usb, I can run it at 32 buffer size with no problem and the levels are very good.
I always liked the idea of the VG99 but never thought it sounded very good and the midi conversion was pants, the GP10 seems to right these issues.
First the GP10 COSM guitars and amps sound far superior, a different league really.
The midi conversion is also much better than the VG99, the high 4 strings actually work very nearly as well as the FTP which is an amazing improvement, the E and A still suffer a bit though but the conversion is way better than any other roland converter I have tried.
The GR300 and Wave synths now work properly with piezo guitars, about time!
The Poly-FX stuff also sounds much better than the VG99.
I am really impressed with the GP10, it is basically half a VG99 which has been done properly. You don't get all the mad setup options that the VG99 has but who cares because it sounds so much better.
I highly recommend the GP10, and you don't hear me say that very often!
Audio files: 213
G2 patch files: 319
PostPosted: Tue Aug 12, 2014 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Not often indeed Shocked
Glad you like it!
Oskar
PostPosted: Wed Aug 13, 2014 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Seems very nice! Price?
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
PostPosted: Wed Aug 13, 2014 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool! That one looks really interesting.
DrJustice
PostPosted: Wed Aug 13, 2014 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
That one went right under my radar.
Better sounding is always good. The VG99 can sound very good IMO, depending on what you want from it, but it requires quite a bit of programming with careful tweaking and judicious use of all the EQ's (they' re everywhere in the VG99).
Is the PG 10 easy to work with? The UI does seem a bit minimal for as deep programming as the VG99 "requires". No FC300 interface either by the looks of it...
GovernorSilver
PostPosted: Fri Aug 15, 2014 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the review! And you know it's well-designed and durable because it didn't break right away in Andy's hands. Wink
Great to know there's a viable option if my VG-99 ever breaks down and I can't get it repaired.
Some old stuff on VIRB
DES
PostPosted: Sat Aug 16, 2014 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow that looks great! Nice to see that you can record/process each string on a different track in your DAW.
www.davesneed.com
GovernorSilver
PostPosted: Wed Aug 20, 2014 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to know if the GP-10 can trigger iPad synth apps over USB MIDI. Some of the initial reaction from early adopters is that the GP-10 might not be able to do this?
GovernorSilver
PostPosted: Wed Aug 20, 2014 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
GP-10 synth demo by someone else:
BobTheDog
Audio files: 32
PostPosted: Fri Aug 29, 2014 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will give it a try over the weekend and get back to you.....
