Problems with sequenzer
Page 1 of 1 [11 Posts]
philpot
PostPosted: Thu Dec 11, 2014 1:19 pm    Post subject: Problems with sequenzer
Subject description: Simulation of a Ryk M185
i just try to rebuild a Ryk M185 sequenzer, but i dont know how to park the sequenzer while the last step repeats for a defined time and then restarts on the next step.....any clues anybody?
thanx in advance
Electromagnetic Wave
G2 patch files: 38
PostPosted: Fri Dec 12, 2014 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
You need to bypass the clock pulses input that come in your sequencer to park it on the desired step. You can use a switch, a lfo, etc... to do it. In the exemple above, I use a mixer with the 'chain input' to stop the sequencer on the last step. You can add another sequencer if you need to stop it on step 1.
I wish this is what you need. Have a nice day!
 Filesize:  150.77 KB
 Viewed:  602 Time(s)
parksequencerv11.pch2
 Filename:  parksequencerv11.pch2
 Filesize:  3.05 KB
 Downloaded:  3973 Time(s)
philpot
PostPosted: Fri Dec 12, 2014 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
first off, thanks for your reply!
i deal with this by stopping my clock via cc controlled by an lfo.
the results are trial an error with the lfo, so i´d prefer to say i.e. step 5 should be repeated 3 times and then the clock starts again.
simply don´t find a way to achieve this.....
ryklike 1.0.prf2
seq is in slot a
 Filename:  ryklike 1.0.prf2
 Filesize:  14.12 KB
 Downloaded:  3999 Time(s)
G2 patch files: 38
PostPosted: Fri Dec 12, 2014 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
after the clock starts again, do you want to go on step 6 ?
philpot
exactly!
G2 patch files: 38
PostPosted: Fri Dec 12, 2014 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I supose that you only want the step 5 to be park every time the loop is repeated ?
and I supose that you want the loop need to finish before to restart to the 1st step ? or you need this sequencer to restart to the 1st step at the same time that an other main sequencer ?
Btw, there is another exemple ..
parksequencerv12.pch2
 Filename:  parksequencerv12.pch2
 Filesize:  4.33 KB
 Downloaded:  4062 Time(s)
philpot
PostPosted: Sun Dec 14, 2014 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
i tried your patch and i get the idea...
i´d prefer a simple 16 step sequenzer where i can switch a note repeat of 1-8 repeats on every single step.
after the note is repeated, the next step should play...
guess there´ll be more guessing and expermentation coming up...Smile
thanks
G2 patch files: 626
PostPosted: Sun Dec 14, 2014 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is an oblique method.
Using basic logic blocks to make a sequencer from scratch.
Only 4 steps and I think I have the connections to the multiplexer wrong but you should get the basic idea.
mk185half.pch2
one half of a M185
 Filename:  mk185half.pch2
 Filesize:  2.37 KB
 Downloaded:  4199 Time(s)
pstnotpd
G2 patch files: 5
PostPosted: Tue Dec 16, 2014 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm trying something similar inspired by the intellijel metropolis.
But I can't seem to stabilize the loop reset. When changing the note length (assigned to a1 buttons) the "park" gets switched off an the sequence gets garbled.
I think it's a timing issue, hence the conversion to pulses
 Filesize:  412.7 KB
 Viewed:  637 Time(s)
Metropolis.pch2
Metropolis sequencer 1st try
 Filename:  Metropolis.pch2
 Filesize:  5.02 KB
 Downloaded:  3987 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Dec 16, 2014 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick'n'dirty literal implementation of your description.
It's a 16-step sequencer with selectable repeats (0-63) per value step.
The sequencer gate rows are also usefully implemented to activate value steps (or skip them if deactivated) and activate repeats (or discard them). Warning: If all value steps are deactivated, the sequencer will race at 24kHz. Laughing
Also, there is a selectable trigger output that either outputs all clock pulses or only those for new value steps, making the circuit also usable as a selectable-step-length sequencer.
There's also a reset button that resets the sequencer counters on the next received clock pulse.
Hope this is what you're looking for.
t
StepRepeatSeq_TK.pch2
Step sequencer with adjustable repeats per step and other features. Read thread for more info.
 Filename:  StepRepeatSeq_TK.pch2
 Filesize:  2.36 KB
 Downloaded:  4137 Time(s)
pstnotpd
G2 patch files: 5
PostPosted: Wed Dec 17, 2014 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that's very close!
I've done some small adjustments which make it even closer to the metropolis. A level amplifier on the repeats to have more granular control (about 8 steps now) and an extra sequencer to control the trigger select per step.
Ditching mine as this is much better Very Happy
steprepeatseq_tk_156_2.pch2
Adjusted version
 Filename:  steprepeatseq_tk_156_2.pch2
 Filesize:  2.9 KB
 Downloaded:  3823 Time(s)
