today> Muied Lumens Frequencies
A delay noodle made in the demo
Page 1 of 1 [5 Posts]
PostPosted: Thu Apr 30, 2015 11:58 pm    Post subject: A delay noodle made in the demo Reply with quote  Mark this post and the followings unread
Goes round and round...
delaynudel.pch2
 Filename:  delaynudel.pch2
 Filesize:  2.75 KB
 Downloaded:  3733 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 02, 2015 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea Stefan, the multiplexers over the delayed and looped versions of a signal .. when did you post this .. anyway, since then been experimenting with that Laughing
And while I took your patch as an example for a class of things to try Razz your example sounds very nice!
Bit like a granular thing almost, the multiplexer interpolation being the envelope, having 8 grains.
I'm toying now with longer delays and modulating some having a 2nd multiplexer pair on them, etc .. fun Cool
You still recognize it?
Laughing
PostPosted: Sun May 03, 2015 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Look at the size of that thing! Shocked Very Happy
Yeah it ended up being something granular, like a lot of things I do one NMG2. The x-mux is a great module. Smile Sometimes I use two standard muxes and fade between them so I can switch/fade randomly between the 8 inputs, rather than just looping over them like it is now.
It would be interesting to hear what your Wren thing sounds like, could you share the patch? Smile
Audio files: 249
G2 patch files: 319
PostPosted: Sun May 03, 2015 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can share the patch later - it will not run on the currently public Wren version ... after seeing your patch I wanted to implement some new things ;-)
Audio files: 249
G2 patch files: 319
PostPosted: Tue May 12, 2015 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, here it is .. finally happy with it all ... it needs the latest Wren (2015.5.12.0) ... implemented some new modules for it Laughing
It may need a bit of a fast computer too .. runs at about 100% CPU load here Confused
(updated the screenshot above too)
2015-05-01-02-bismuth.wren
Bismuth, a Wren patch after a G2 patch made by Antimon
 Filename:  2015-05-01-02-bismuth.wren
 Filesize:  65.51 KB
 Downloaded:  406 Time(s)
