 Forum index » Instruments and Equipment » Percussa Audio Cubes
Percussa releases new IMPROVISOR, updates MIDIBridge to v3.1
Post new topic   Reply to topic Moderators: bschiett
bschiett
PostPosted: Sat Jul 04, 2015 7:53 am    Post subject: Percussa releases new IMPROVISOR, updates MIDIBridge to v3.1 Reply with quote  Mark this post and the followings unread
Last week, we released MIDIBridge v3.1 and it is available in the download section of our website. IMPROVISOR, the generative MIDI Sequencer for AudioCubes, is now part of the updated MIDIBridge 3.1, as a separate mode in MIDIBridge.
Since we received a lot of feature requests from AudioCubes users, we decided to turn the Max/msp patch into a C++ application from scratch, at the same time integrating it into the MIDIBridge code base. Because of these changes, the performance of IMPROVISOR is much improved.
IMPROVISOR is a generative MIDI sequencer that lets you program velocity and semitone patterns. Each AudioCube is linked to a looping step sequencer which uses a relative pitch (semitone) and velocity pattern. When AudioCubes detect each other, the semitone patterns of their sequencers add up to each other and to the root note of their sequencer. When turning AudioCubes, different velocity patterns are used with the same pitch patterns.
You can download MIDIBridge v3.1 in the download section of our website. The latest version works Percussa Wireless AudioCubes PRO as well with Percussa Wireless AudioCubes.
percussa mSSP - digital modular in a eurorack module - 8 in/4 out @ 48/96/192khz DC coupled - 25+ DSP modules https://www.kickstarter.com/projects/percussa/percussa-micro-super-signal-processor-eurorack-mod
