 Forum index » Instruments and Equipment » Samplers
Re-triggering a playing note in a sampler
djnik1362
PostPosted: Fri Mar 25, 2016 7:03 am    Post subject:  Re-triggering a playing note in a sampler Reply with quote  Mark this post and the followings unread
Hi everyone.
I've designed a hardware sampler which using a linear interpolation and decimation . It uses 16-bit PCM mono or stereo samples . I have not implemented an ADSR envelope and i just playback samples at given ratio of interpolation and decimation .
My problem is when i receive a trigger on a playing notes . Because i simply start from beginning of sample after receiving each trigger when a re-trigger happens there is a click or noise on output . I survey the KONTAKT sampler and find out KONTAKT use a almost complex algorithm when re-triggering occurs .
In high pitch notes KONTAKT use a fade out to zero and then start again but in low pitch notes if re-triggering happens very fast because samples are away from zero it starts almost about last level of sample . I mean in low pitch notes and in situations that re-triggering happen very fast (for example 100 ms after first trigger) attack of sample starts from last level of playing note .
Is there anyone familiar with this technique ?
Thanks for your support .
