Binary Game Sequencer
Page 4 of 4 [91 Posts]
Audio files: 134
PostPosted: Sun Feb 01, 2015 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
nice demos dave Very Happy
Thanks Phobos Very Happy
epicyclus@skrogmusic.plus.com
Audio files: 134
PostPosted: Sun Feb 01, 2015 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
wackelpeter wrote:
indeed very nice demo... should put this too on my do list...
are the percussive sounds are all from your diy drum machine? if so... wow!!
sounds very charming.
Thanks Smile .
All the drum sounds are from the new yellow drum synth Smile ...... http://www.electro-music.com/forum/topic-62648.html
Audio files: 134
PostPosted: Sun Feb 01, 2015 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
it is nice to see that you have fun to play with the module and develop it further to your needs...
Thanks again for uploading the circuits , Matthias , when I first heard your euro build demos , I knew I had to have this module in my system Very Happy ,when the module is cycling round, it reminded me of watching the leds fill up the division steps on your simple clock divider I built a few years ago.... http://www.electro-music.com/forum/topic-46786.html .
Although I have modded the binary sequencer towards mostly VCO use ,when clocked in time with my VCPS8 sequ, it has been spewing out ideas for new songs/tracks , I have already got 2 new Epicyclus album basic tracks laid down using this after testing & calibrating , cool Very Happy Very Happy .
PostPosted: Wed Feb 04, 2015 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
fonik wrote:
since this new version is bi-polar you could use the external inputs for audio as well.
I have not tried audio yet Smile , i'll have a go through the week Smile
mmh. since you limited the range of the higher divisions attenuverters you will have a mixer with pre-attenuation. not sure how usefull this is then...
Tech Budday at Random*Source
Paradigm X
PostPosted: Wed Feb 04, 2015 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, just listening to the demos now. dont know how ou get the time man...
sounds amazing
and wow at getting the thing going and even improving it...
and great invention fonik too!
Audio files: 134
PostPosted: Thu Feb 05, 2015 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ben .... Thanks Smile
Audio files: 134
PostPosted: Thu Feb 05, 2015 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio test.......
Yes Matthias, the lowest divisions attenuate the singnal too much with my mods , but that's ok , I will mainly be using it's CV's into the Soundlab++ & modular vco's Smile .
Setting the attenuverter to external inputs only , I patched various sounds from the modular to the first 5 inputs .
The sounds as they are switched on through the mp3 file below.....
As the sounds layer up when the division cells clock / stack up, the balance of the summed volumes varies slightly producing an interesting volume effect.
/32 = highpass white noise.
/16 = pwm square wave vco.
/8 = ring mod(2vco's) swept with LFO.
/4 = grainy noise.
/2 = vco with vc-lfo modulation.
Also I just had to put some basic drums on too Very Happy.
This test demo has ended up a wee bit like early Fad Gadget or The Normal Smile cool.
Binary sequencer audio test & drums.mp3
 Filename:  Binary sequencer audio test & drums.mp3
 Filesize:  5.71 MB
 Downloaded:  509 Time(s)
wackelpeter
Audio files: 10
PostPosted: Thu Feb 05, 2015 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds really nice thumb up
and btw. Fad Gadget and The Normal are always a great reference...
Audio files: 134
PostPosted: Sun Nov 22, 2015 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
Finally got the order of stickers I need for a few Fonik projects, yay Very Happy .
A job to finish off from earlier this year , proper sticker for the binary sequencer I built.
On the tester layout I printed before , I changed the vertical row of led's & "A" / "B" switches around , during operation I found I was knocking the cv pots when switching , now the new layout has more finger space.
 Filesize:  440.8 KB
 Viewed:  201 Time(s)
PostPosted: Tue Nov 24, 2015 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey, this looks just great.
alas, it reminds me that i should turn this into a proper project. Embarassed
diablojoy
PostPosted: Thu Jun 16, 2016 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
just a gentle nudge Laughing
hmm was wondering also if instead of or maybe as well as A / off / B switches
if there were an easy hack to put in an expander for gating these 2 x jacks per stage and a bunch of 4016's edit: make that max313's forgot the bipolar bonus may give the option - off / A / B / both in that case.
cheers matthias
ask where the hell am I
as good an answer as any
PostPosted: Sun Jun 19, 2016 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
diablojoy
PostPosted: Sun Jun 19, 2016 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
lol nothing to be embarrassed about stuff gets in the way
I started a new job recently with far better hours hopefully I now get some time back for DIY . sadly been lacking that, old job was 24/7 /365 so I never could plan anything.
anyway I might take a swing at it for euro. if I come up with anything half decent will let you know
PostPosted: Mon Jun 20, 2016 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
the new schematic is done already. i even already started to layout a board, alas i did not finish it yet.
diablojoy
PostPosted: Mon Jun 20, 2016 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
the scheme on page 2 of this topic ?
PostPosted: Mon Jul 25, 2016 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
yes
