<on air> Currently on the open port test
  Various Artists electro-music.com March Equinox Concert
 Forum index » DIY Hardware and Software » PAIA Equipment
Old PAIA 47xx modules, new project
Page 1 of 1 [11 Posts]
Cfish
PostPosted: Thu Nov 10, 2016 6:21 pm    Post subject: Old PAIA 47xx modules, new project Reply with quote  Mark this post and the followings unread
Had these PAIA 4700 series modules for a while. Finally decided to do something with them.
It's starting to come together.
 Filesize:  1.49 MB
 Viewed:  246 Time(s)
Cfish
PostPosted: Sat Nov 12, 2016 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone happen to know what size banana jacks these are?
I need to order patch cables, and got it wrong on my first try.
RC2525
PostPosted: Tue Nov 15, 2016 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nicely done!
The patch cables that carry control voltages are known as pin tip jacks, essentially the same thing that is used by many multi-meters. Not really banana jacks, they are thinner and they don't stack. Most likely you will just find the tips (rather than a complete patch cable) and have to make your own patch cable. One user tried speaker pin plugs from RadioShack and they worked. You can order the pin tip jacks from Mouser.
Mouser part 530-105-0302-1
Alternatively, you could replace the pin tip jacks with banana jacks.
Cfish
PostPosted: Wed Nov 16, 2016 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks RC2525. Got some ordered.
Audio files: 613
PostPosted: Wed Nov 16, 2016 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
spotted it in another photo and I like it Razz
Also reminds me of my Lun-A-Key but I bet it is a big bigger.
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
Cfish
PostPosted: Wed Nov 16, 2016 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PhoBos
DES
PostPosted: Sat Nov 19, 2016 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's cool! Looks like an Oz on steroids! Smile
www.davesneed.com
Cfish
PostPosted: Sat Nov 19, 2016 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dave.
Have my own version of the OZ that sits right beside it.
 Filesize:  1.29 MB
 Viewed:  225 Time(s)
Cfish
PostPosted: Sat Nov 26, 2016 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm trying to figure out a power supply for this little system using things I already have.
I have a prebuilt +-9v regulator and and an 18 volt center tapped transformer, but it don't look like that will do.
I have a spare 30v center tapped transformer I could use and get the +-9v while making some extra heat I'm sure.
With an extra 18v regulator for the positive rail, seeing when rectified the transformer produces about 22v per rail Dc
The real question is will the 18v be to noisy?
Audio files: 613
PostPosted: Sun Nov 27, 2016 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the 18V of the center tapped transformer a measured voltage or what it is labeled at ? I think you might be able to get away with using that one.
It looks like a very small system and I don't see any leds so the power consumption is probably low. Although I can 't tell without seeing the
actual circuits or even better measuring it. But with a small load the output voltage of the tranformer might be higher and even if it is 18V I don't
think it would be a problem. I wouldn't recomend it for a modular system that will be expanded in the future but for something like this I think it is
worth a try.
Cfish
PostPosted: Sun Nov 27, 2016 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PhoBoS
The 18v is labeled AC RMS voltage. Will se what it comes out to DC rectified later today.
the 1496 ICs in the balanced modulator VCAs are the only thing that uses the +18v and -9v rails for power.
EGs use +18 to ground and filter uses +18 to ground. But filter sounds the same using +9 to ground on my bench supply.
VCOS are +-9v rails
If the load is to high I could try running the EGs on the +9v rail to ground. That would leave the 2 1496 ICs as the only load on the +18v regulator.
Not sure how that might affect the EGs function. I have not looked at the E.G. Schematics very closely yet
