<on air> Various Artists electro-music.com March Equinox Concert
Real Ring Modem?
Page 1 of 1 [6 Posts]
Abby Normal
PostPosted: Thu Jan 10, 2013 7:03 pm    Post subject: Real Ring Modem?
Subject description: Does anyone have this as a module?
Hello - Can anyone shed some light on the Real Ring Modem?
http://www.cgs.synth.net/modules/cgsrmodem.html
How does this differ (sonically speaking) from using just one ring mod? Are there any hidden benefits that I'm not seeing?
bbow73
PostPosted: Fri Mar 13, 2015 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
same question
Audio files: 229
G2 patch files: 319
PostPosted: Sat Mar 14, 2015 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
It is just some effect you can obtain by using two ring modulators ... it is not that it is a different ring modulator, just two being used.
As the modulators are not ideal I'd expect some distortion and some remaining sum and difference frequencies ... as in shortwave radio like sounds ... could be interesting with some filtering in the modulated signal before demodulating.
But then again I never tried it ...
abelovesfun
PostPosted: Mon Jul 06, 2015 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have one. It definitely sounds different from my MFOS ring modulator. I'm glad I have both. I should do an A/B and record the difference...
Hans Kockelmans
PostPosted: Tue Jul 07, 2015 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I have one also. The thing is called 'real' because this is the schematic used in the 50's. It is easy to build using 1:1 transformers and germanium diodes.
Fernando
PostPosted: Mon Dec 05, 2016 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
The interesting thing of setting up a ring modulator-demodulator is to insert processors between the two sections,
so at the end of it (at the output of the demod) you don't have the original signal back (as originally designed by radio engineers in XXth century)
but something musically interesting! : )
