Sparkfun Tsunami Super WAV Trigger Board
Page 1 of 1 [4 Posts]
JovianPyx
Audio files: 212
PostPosted: Mon Feb 20, 2017 10:22 am    Post subject: Sparkfun Tsunami Super WAV Trigger Board Reply with quote  Mark this post and the followings unread
https://www.sparkfun.com/products/13810
I've ordered one of these because it looks like fun. Anyone else see this? Polyphonic up to 32 voices, 8 mono outputs or 4 stereo outputs. WAV file storage on micro SD card. Should work nicely in combination with a Raspberry Pi to sample and write wave files to the SD card. Could also be fun to generate WAV files with programs.
Time flies like a banana.
corruptio optimi pessima
Dan Lavin
Audio files: 21
PostPosted: Tue Feb 21, 2017 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been using the Wav Triggers for the past 18 months or so. I love them as they let me load just the sounds I want to use, rather than buying a rompler and only using maybe 10 of 200+ sounds that come with factory units. I will probably get a tsunami board at some point.
Synth DIY since 1977!
JovianPyx
Audio files: 212
PostPosted: Tue Feb 21, 2017 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... I thought the Tsunami was a WAV Trigger, but it seems like you're referring to a different device... ??
LFLab
PostPosted: Wed Feb 22, 2017 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
The wav trigger was an earlier, simpler version of the Tsunami.
