The program of driving OLED by PIC18F13K22
ailex1995
PostPosted: Thu Apr 13, 2017 2:17 am    Post subject: The program of driving OLED by PIC18F13K22
Subject description: programming,hardware
Good afternoon~all, I met some troubles when I am working on the program about driving OLED by PIC18F13K22. Does anyone here can help me out?
Look! The program I wrote is as followings:
Code:
void init_fosc(void)
OSCCON = 0xF7;//16MHZ
void init_gpio(void)
     ANSEL=0x00;//inputting enabled digital
     ANSELH = 0x00;
     PORTB=0;
     LATB =0;
     TRISB =0xFF;
PORTC=0;
LATC=0;
TRISC =0x00;
void init_i2c_master()
    TRISB4 = input;
    TRISB6 = input;
    SSPCON1bits.SSPM0 = 0;
    SSPCON1bits.SSPM1 = 0;
    SSPCON1bits.SSPM2 = 0;
    SSPCON1bits.SSPM3 = 1;// I2C Master mode ,clock=Fosc/(4*(SSPxADD+1))
    SSPSTATbits.SMP = 0;//enabled slew rate: under the speed 400khz
    SSPADD = 0x09;//SCL CLOCK Frequency 400KHZ
    SSPCON1bits.SSPEN = 1;
void i2c_master_tx(unsigned char tx_deviceaddr,unsigned char tx_resaddr,unsigned char tx_data)
     PIR1bits.SSPIF = 0;//the software need to set 0
    SSPCON2bits.SEN = 1;//the start conditions
    while(SSPCON2bits.SEN == 1);//SEN hardware will reset after finishing the start conditions
    // PIR1bits.SSPIF = 1;   Setting 1 by hardware
    SSPBUF = tx_deviceaddr;//the device site
    while(ACKSTAT);  // ~ACK
    while(PIR1bits.SSPIF == 0);
    SSPBUF = tx_resaddr;//writing the register which need to order
    PIR1bits.SSPIF = 0;
    SSPBUF = tx_data;//writing data
    PIR1bits.SSPIF = 0;
    SSPCON2bits.PEN = 1;//Stop condition
I have also writen the OLED shows and initialization as well as the I2C agreement of hardware. It can operate perfectly by analogue I2C in the 51 SCM. Why can’t it communicate by using simulation and the I2C of hardware on PIC ?
This is the PIC18F13K22's datasheet: http://www.kynix.com/uploadfiles/pdf65976/PIC18F13K22-E2fML_965602.pdf ,please have a look if needed.
Thank you in advance!
Have a nice day~
