Antimon Waves
Page 3 of 3 [75 Posts]
Goto page: Previous 1, 2, 3
Audio files: 219
G2 patch files: 319
PostPosted: Fri Nov 17, 2017 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I liked the dirt, worked out well then :-)
PostPosted: Sat Nov 18, 2017 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan! Very Happy
Audio files: 132
PostPosted: Sun Nov 19, 2017 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
nice sounds on friday show Smile
epicyclus@skrogmusic.plus.com
PostPosted: Mon Nov 20, 2017 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Dave, thanks! Very Happy
PostPosted: Fri Nov 24, 2017 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's number #17, which apparently is 51/3.
I set up a guitar to play with on this one. The idea was to loop it, but at the end I broke a rule I had set up for myself that I was not going to do any guitar improv (because that's not techno Wink ), but it was fun to play nonetheless. Smile
A minor moving to G at the end.
Antimon Waves 2017-11-24.mp3
 Filename:  Antimon Waves 2017-11-24.mp3
 Filesize:  83.16 MB
 Downloaded:  169 Time(s)
Audio files: 584
PostPosted: Fri Nov 24, 2017 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
it was a very nice set!
SoundCloud BandCamp Stickney Synthyards Captain Collider
Audio files: 132
PostPosted: Sat Nov 25, 2017 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice sounds last night Stefan Smile
PostPosted: Sat Nov 25, 2017 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot PHOBoS and Dave! Very Happy
PostPosted: Fri Dec 01, 2017 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Antimon Waves #18. Besides the usual stuff, messed around with a vocoder setup as well as my new Hank Drum.
Antimon Waves 2017-12-01.mp3
 Filename:  Antimon Waves 2017-12-01.mp3
 Filesize:  88.34 MB
 Downloaded:  168 Time(s)
Audio files: 132
PostPosted: Sat Dec 02, 2017 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
great set , i like those drum sounds Smile
PostPosted: Sat Dec 02, 2017 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dave, much appreciated! Very Happy
PostPosted: Fri Dec 08, 2017 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show number 19!
I made a vocoder patch on the G2 which worked a little better than last time I tried a vocoder in Live. Also made a jingly bells patch on the G2. rendeer
And synths, sequencers, synths, sequencers...
Antimon Waves 2017-12-08.mp3
 Filename:  Antimon Waves 2017-12-08.mp3
 Filesize:  97.1 MB
 Downloaded:  159 Time(s)
PostPosted: Sat Dec 16, 2017 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
...aaand after some CPR and band-aids, here's show number 20!
It's the second time Audacity has crashed on me during the set, but the first time I've managed to keep my head cool enough to not delete Audacity's temp files by restarting and clicking "yes" in the dialog that asks if you want to delete the old files :S , so that there was something to resurrect. I lost a few seconds on one of the stereo channels, I've patched it together enough so that it's only noticeable as a slight stereo glitch around the 50 minute mark, and only if you really pay attention.
Anyway, after another hectic week at work I felt like taking it a bit easy again, leaving the drums aside for the first half while I attempted to mimic some kind of 80s minimalism. Some ad lib singing and guitar playing.
Edit: I notice what sounds a bit like slight digital clipping in the second half of the recording. It's not really surprising, I've seen how the meters hit the roof on all of my Waves sets, amazed at how the limiters and compressors have saved me, but I guess I reached the limit on this one. Will try to adjust the sound down a bit for next time, which incidentally will be two weeks from now at the soonest.
Antimon Waves 2017-12-15.mp3
 Filename:  Antimon Waves 2017-12-15.mp3
 Filesize:  88.13 MB
 Downloaded:  148 Time(s)
Audio files: 584
PostPosted: Sat Dec 16, 2017 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
ah you managed to get it ressurected, awesome! cheers
it's a very nice set, will listen again to it later today.
PostPosted: Sun Dec 17, 2017 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, and it continued recording even though the GUI froze ten minutes before I finished, so I got the whole thing. Nice to know for when this happens in the future. I probably should get a new streaming solution though...
Tricky business though: Audacity saves lots of files, each containing a six second chunk, and when recording stereo every odd numbered file is one stereo channel and every even numbered file is the other. So I had to run a script that first removed all odd files, another script that compiled those into a big file that I then imported back into Audacity, then repeat the procedure for even numbered files, resulting in two tracks in Audacity. Then, pan one hard right and the other hard left, and then find the place where some seconds where lost, nudge one channel until it was in sync with the other, and then you're done for exporting to an mp3. Whew! colors
PostPosted: Fri Dec 29, 2017 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show number 21, last one of the year!
Lots of buffering on my stream apparently, hopefully it will more enjoyable in this downloadable form. Wink
I made a couple of new tricks on the G2, a random chord generator, impulses through comb filters, and something else. Otherwise prettty much business as usual.
Antimon Waves 2017-12-29.mp3
 Filename:  Antimon Waves 2017-12-29.mp3
 Filesize:  89.7 MB
 Downloaded:  136 Time(s)
Audio files: 353
PostPosted: Fri Dec 29, 2017 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yay! Sounds great without the buffers! Very Happy
Muied Lumens Base Star
PostPosted: Sat Dec 30, 2017 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob, that's great to hear! Very Happy
PostPosted: Fri Jan 05, 2018 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show number #22, first one for 2018!
My dodgy internet connection robs me of some of the excitement when doing these sets, the main idea is to connect with people in chat. I think I hit a couple of groovy sweetspots in this set, but there parts (especially in the middle) where I got stumped, not knowing what to do.
Some new G2 patches for making random chords and noise in this one.
Antimon Waves 2018-01-05.mp3
 Filename:  Antimon Waves 2018-01-05.mp3
 Filesize:  93.12 MB
 Downloaded:  142 Time(s)
PostPosted: Fri Jan 12, 2018 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show number 23!
Cranked up the distortion pedal for some guitar. Tried some fast but sombre arpeggions. Other than that, synths and sequencers, surprise! Very Happy cherry
Antimon Waves 2018-01-12.mp3
 Filename:  Antimon Waves 2018-01-12.mp3
 Filesize:  89.68 MB
 Downloaded:  143 Time(s)
PostPosted: Fri Jan 19, 2018 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show number 24, now there are waves to fill every hour of the day! Very Happy
Some echoy drums, a couple of new nmg2 sequenced synth sounds, some more guitar riffin'
Antimon Waves 2018-01-19.mp3
 Filename:  Antimon Waves 2018-01-19.mp3
 Filesize:  85.62 MB
 Downloaded:  144 Time(s)
IanCraig
PostPosted: Mon Jan 22, 2018 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounding great Antimon Very Happy
PostPosted: Mon Jan 22, 2018 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian! Very Happy
PostPosted: Fri Jan 26, 2018 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Show numero 25. I recently acquired a Korg Monologue and put it to use here. I still have to learn more about it, but I think I got some cool sounds. Added some oohs and aahs.
Antimon Waves 2018-01-26.mp3
 Filename:  Antimon Waves 2018-01-26.mp3
 Filesize:  79.06 MB
Audio files: 143
PostPosted: Wed Mar 21, 2018 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Sadly, this is Antimon's last post on electro-music.com. RIP friend. You will remain an inspiration to me.
